Moshammer Ducktail V2
#121
Well that's interesting and adds another potential wrinkle into the mix.
You'd have to strip the car down to do the test fit and then what ?
You're clearly committed at that point and you have a part that was sent over from Berlin.
The piece does come with all mounting hardware and they state that there is plenty of built in adjustment with the hardware
I'm going for it, the worst that can happen is a minor panel gap issue and I can certainly live with that if everything else is spot on.
I did remember that they sent a link for installation instruction for the ducktail, it's a 22 step process from start to finish and you do need to code out the lift function.
It's an easy DIY if you have the tools and the mechanical aptitude. There is also a good You Tube post where the guy is adding an aero kit to his carrera so you see all the steps needed to remove the factory spoiler, lift mechanism and such.
#122
Here is the link to YouTube, the first part shows how to remove the stock spoiler and lifting mechanism.
Lots of good info on the disassembly needed to install the duck tail.
#123
https://youtu.be/G4UhKd0vyes?si=Z_YkYrWmri3MDIvD
PJ Franks has proven to be a competent DIY’er.
He’s posted more than one helpful video and this one is certainly thread worthy.
This is going to be interesting.
#124
Moshammer EVO II has arrived...
Ordered on December 21. Arrived on January 22nd. Total cost $2300.
Next step head to dealer for active aero spoiler deactivation.
Still not sure if I'm gonna go the DIY install route. PJ's video is helpful...but there are quite a few gaps in his sequence and as a result a few questions. Not to mention Moshammer's clear admonitions against self-install (liability concerns).
Side marker lights, Frunk Lid Liner, Lip Spoiler, GT3 Side Skirts, Clear Rear 3rd light, Numeric Pedals, DB Carbon Fiber on the center console, 10mm spacers, Kies TLG Mud flaps...yeah I can do those, but this might be above my skill level. It's not exactly a "simple" bolt on. Consulting a few local shops for fitment/install...then paint.
Stay tuned...
Yeah...I was concerned too. But Germany is a long way from California!
Arrived intact.
Looks to be quality construction.
Stay tuned...
Arrived intact.
The following 4 users liked this post by REIN911:
#126
I'm glad your spoiler looks unscathed compared to the box it came in @REIN911
My box got beat up too, but not like that !
Looks like they threw a round a few times, and then dropped kicked it out of the delivery truck !
Glad it arrived intact, looking forward to following your progress.
I drop mine off tomorrow for paint, and then the fun will begin.
#127
#128
Stay tuned...
Arrived intact.
Stay tuned...
Arrived intact.
#129
I want to have them code out the lift function when they do some coding stuff for the windshield replacement.
If not, will have to go the after hours route (cash money)
#130
Did the kit come with anything else besides the fiberglass ducktail spoiler? For example, did it come with a new base plate to replace the base plate that the retractable wing attaches to? This is the new base plate that Porsche supplies with their aerokit wing. I'm glad that they have this super sturdy base plate that the wing attaches to. Just curious to see how the Moshammer ducktail is attached to the car:
The four mounting points along the lower edge are where you add the supplied brackets to attach the lower edge of the spoiler. You can see the two upper tabs in the photos of the ducktail.
#131
DIY installation EVO II
I'm probably going the DIY route, I'm dropping the car off this week for a new windsheild and tires and
Please keep us posted.
#132
The ducktail utilizes the factory base plate just like the one you just purchased. The stock spoiler lift mechanism inserts into the location where you have the two mounting plates on the left and right of the inter cooler openings.
#134
"The ducktail utilizes the factory base plate..."
"The stock spoiler lift mechanism inserts into the location where you have the two mounting plates on the left and right of the inter cooler openings."
The four mounting points along the lower edge are where you add the supplied brackets to attach the lower edge of the spoiler."
Take a closer look at post #115....also see the pieces/parts from the VarTheVar posts.
AlterZgo (01-23-2024)
