Newbie here: T vs S
#31
Interesting to hear that the selling point of the T is the sum of its parts, but a GTS is just an S with 30HP more.
#32
@90292_911 Agreed re PTS BY. Not to be a Debbie Downer, but PTS is not happening for any 2024 992 at this point. I wish it was untrue, but it isn’t.
@johnarpy You have Python Green, not PTS Viper Green. Python is NLA.
#33
Received 2,842 Likes
#34
Whether you think of that acceleration as coming from the torque or as a rate of change of kinetic energy (power) doesn't seem relevant.
And since the gearboxes are the same across the carrera range, there is no such thing as more torque without more power. They aren't independent. I.e. any point in the rev range, if there is more torque, there is also more power.
CanAutM3 (09-07-2023)
#35
I'm not sure that makes a lot of sense. What people would notice is acceleration as that is what would impart a force for them to notice.
And, if I may, I think aggie57 was a bit loose with his terminology. I think he meant horsepower, instead of just "power".
But regardless, without getting into automotive logomachy, the point is that even if two cars had the same amount of torque, when and how and that torque is delivered (i.e., its torque curve) will make a significant difference in driving experience for hoi polloi, if not everyone in general, including experienced drivers.
#36
I think you're missing aggie57's point.
#37
And I understand torque curves. But there's a power curve with the equivalent information (i.e. either curve can be derived from the other; they aren't different pieces of information; that's not the same as saying torque and power are the same, so don't twist it that way TIA).
Yes, I agree, it's the curve that matters. But to talk about torque "over" power in that context makes no sense. Unless you are at zero rpm, torque doesn't exist in isolation. It exists at an rpm and has a specific power to go with it. And again, it even makes perfect sense to think of this acceleration force one feels as a rate of change of energy. But, you can also think of it as a force applied (torque). Either one. But not one over the other. That's the part that doesn't make sense.
Here's a post I made on the Taycan Forum last year explaining how you can approach 0-60 times (as an example) from either power or torque.
https://www.taycanforum.com/forum/th...-3#post-160259
What is aggies point that I missed?
#38
Horsepower is just a unit of power. I don't understand your distinction.
I don't disagree with you that 0-60 times can be approached from either a pure horsepower or torque perspective.
That's really not what we (meaning, aggie57) and I are talking about).
It's more about how that power is delivered. If the torque curve basically peaks at 2k RPM, the car will feel faster than a car with a torque curve that peaks at 7k RPM, because unless you're on track or driving like a hoonigan you spend most of your life under 5k RPM. This is really why FI engined are so much better for daily commutes, even though no one here likes to admit it.
This is essentially the "butt dyno" at work.
aggie57 (09-05-2023)
#39
My friend, I think we are speaking past each other.
All I was originally saying is that all of the higher trim power can be used. Aggie replied that they feel torque more than power. I maintain that doesn't make sense because they aren't independent. You're free to disagree.
#40
#42
You can have two cars of equal hp, one with a lot of torque and the other delivering power through high RPM. The character of power delivery and the experience of driving those two cars will be different.
The following 3 users liked this post by rk-d:
#44
what I’m responding to is someone saying “horsepower is more than torque” at a particular rpm, which is a meaningless comparison.
#45
And there's more power there too. So again, no reason for the distinction.
