Break in period - real or myth?
#31
I believe it to be real and follow guidelines with new cars. As noted above, goes beyond engine to other mechanical parts also.
Having said that, watching production videos, every engine is tested in factory before being installed to ensure it meets performance - what kind of engine speeds to they run in those tests!
#32
#33
Vids
Icegrill (04-21-2023)
#35
It's not so easy if you drive your car 2k miles a year. Which wouldn't be too uncommon for a lot of Porsche owners. Still worth doing IMO. I'm doing it but I only have 250 miles on it after 2 wks, at this rate it will take me 4 months LOL.
AdamIsAdam (04-21-2023)
#36
I applied a modified version of this (Weissach method) to my GTS, lowering the rev limits by 1000 rpm for each check point. Certainly didn't hurt and I'm not burning any oil. I think its more important to keep the revs down until oil temp is up. I live in a relatively warm climate and drive in Normal and keep revs below 3000 until over 160 degrees (why 160 is too convoluted to explain), 4000 until over 180. Then everything is on the menu. OBTW, PDK 8th gear gives about 125mph at 3000 RPM.
#39
Why are people debating what is on page 16 of our manuals? If you want to ignore the advice because it "infringes" on your enjoyment, by all means, go ahead. I have about 800 miles and I know that there is what someone else described as the "fun zone" on the other side of 1800 miles. I'm not a lemming if I listen to the manufacturer's recommendation. This topic is a fascinating insight into human behavior....and privilege.
ZacapaXO (04-25-2023)
#40
Now that that is finally settled, who do we think killed JFK?
#41
Wait, JFK is dead? What happened?
#42
Bob Barker has been shot, really!
#44
Will legitimately take me less than a week or so to get to that mileage
joydrive (04-22-2023)
The following 4 users liked this post by dudeoverthere:
