Thinking of trading up to a GTS
if you have the money, do it!
Trade down to a base. Every other model is too fast and boring.
Received 2,842 Likes
I went from 2020 C4S PDK to a 2022 GTS MT RWD, amazing difference obviously. If you’re going with the same drivetrain options, the difference would be much less. The 22 is also much more refined with the updated PCM, and the interior has most of the bugs worked out. Bose woofer, rear entry release strap, homelink etc.
GTS? YES!!
Get one with the AeroKit too, if you get a coupe.
Scott P (02-21-2023)
If you already have an S, it’s not that big of a leap or step. If you are looking to go from PDK to manual, sure, it’s worth it. If you’re looking to do a completely different spec, also worth it.
The more interesting transition is from an S to a T. 🤔
Was there a reason why you got a cab to begin with?
pkalhan (02-20-2023)
Not a big performance upgrade. If you're dissatisfied with your car, sure. But its not a quantum leap in performance, handling. etc. So, unless there's something about the GTS is a gotta-have-it, then upgrade. Otherwise?
Why not a Turbo S?
GTS in a vert also?
Why do you want to make the switch?
Address these questions and you will get more meaningful responses.
