Homelink during Reverse
Old 02-15-2023, 03:31 PM
jlegelis
jlegelis's Avatar
>> For MY22 they presented the homelink button at all times in the PCM, and changed the diamond button behavior so if only one profile is saved pressing it sends the open/close signal. A vast improvement but still not perfect.
Those are some simple / elegant fixes to a silly 'bug' - frustrating if they don't backport that to a PCM5 update. Given that it's just software it should be simple.
Old 02-16-2023, 08:17 AM
TK42ONE
TK42ONE's Avatar
Originally Posted by reddsektor
is that even possible, or is it a new MY thing? I thought hitting any progammed button just pops up the profile on the pcm and still makes you actually have to then tap the profile to open/close the door..
On my 23 the button is programmed and once pushed it opens and closes the door. On my 21 it would only pull up the homelink screen which was frustrating...1st world problem.
Old 02-16-2023, 09:57 AM
garthg
garthg's Avatar
Originally Posted by dixonk
I have my steering wheel diamond programmed for the door. When I back out I just hit the button and the door closes. I don’t believe I have ever used the PCM to open or close the door.
We have two doors, so when I hit the Diamond button Homelink pops up. Same idea.
Programming homelink was the same as any other vehicle for me. Push the programming button on the back of the door opener and then the Homelink button in the car. I had no issue programming for two separate doors.
Old 02-16-2023, 11:15 AM
Frank996
Frank996's Avatar
Originally Posted by woobiee
Same here. I also disabled the GPS function for homelink... annoyed me more than it benefiting.
Want to do the same tbh... Where can I remove the GPS location setting only without having to re-do the whole setup, or is that not an option (I half heartedly tried to look for it the other day)?
Old 02-16-2023, 11:45 AM
woobiee
woobiee's Avatar
I don't remember where exactly but it's definitely in the PCM menu somewhere. I'll take a look later tonight if you haven't found it yet.
Frank996 (02-17-2023)
Old 02-16-2023, 07:57 PM
icanthelpit
icanthelpit's Avatar
Me too - I know when I’m home.
Old 02-16-2023, 08:15 PM
woobiee
woobiee's Avatar
If you haven't found it, to remove the GPS location,
PCM6
Homelink
>Tap on the three dots next to your saved Homelink connection (...)
>Delete Location
This retains your connection but deletes the GPS saved location for said connection.
Old 02-17-2023, 06:58 AM
Frank996
Frank996's Avatar
Thanks a mill @woobiee Found it and removed it... We're now all good to go :-)
Never had a problem with it not popping up when needed, but prefer the manual method.
Quick Reply: Homelink during Reverse
