Stuck spoiler
Stuck spoiler
Hey All,
Long time follower, first time poster. Purchased my first 911 in November a new 992C2. Purchased the car at a dealer in Boston and drove it all the way home to Louisiana. Have loved everything about the car to this point! Was diving this weekend in wet conditions when the car prompted me to switch to wet mode, which I did without issue. When I parked the spoiler was extended to intermediate mode. I attempted to manually lower it but it will not move. I attempted to switch to different drive modes, same issue. I let the car sit overnight, rise and repeat, same issue. There is nothing obstructing the spoiler that I can see, it seemingly is just frozen.
Anyone have any suggestions for getting the spoiler lowered? Closest dealers to me are in Baton Rouge and Houston, both two plus hours away! Both of which also wont give me a loaner as I don't live in close proximity nor did I purchase the car from them, which I understand....to an extent. I appreciate any and all help.
Thanks!
Thanks!
Have you tried disconnecting and reconnecting the battery? Maybe that may reset the system? Are you getting any warning messages on the dashboard or on the PCM? What happens when you go to the screen to raise/lower the spoiler manually and push the button? Does the display show any animation of the spoiler coming down? Or does it just stay in the up position? Any message showing on the PCM screen?
Fuses checked?
Thanks for the quick response. I guess it would help if I provided more information, sorry about that! Haven't reconnected the battery. No error or warning messages on dash or PCM. When I go to manually adjust the spoiler I get the normal message of push and hold to lower. I do so and literally nothing happens. The display gives me the animation of the spoiler but it just stays highlighted. Eventually after a minute or so the spoiler box will uncheck itself, I'm assuming it thinks its completed lowering?
Do you have a camera pointed at it. 992 spoilers are infamously known to peacock for cameras.
The following 7 users liked this post by 3rdpedal:
adrianp89 (02-06-2023),
asunnyhero (02-07-2023),
Jeff Whitten (03-09-2024),
offminorthreat (02-16-2023),
Radiationman (02-06-2023),
and 2 others liked this post.
Given how instrumented these cars are and how integral the spoiler is to the driving safety of the car, I'd be shocked if an out of position spoiler wasn't throwing some kind of very loud warning. I'd check what others have mentioned: Fuses, 'user error', then disconnect the battery. If you have Sport Plus then you can move the selector to Sport Plus mode and drive around a bit and the spoiler should be pretty active...
Thanks all for the suggestions! I will check the fuses, then try to disconnect the battery. I have experimented with all drive modes, including sport plus. The spoiler remains in intermediate mode throughout the different mode cycles. Certainly will not take offense to the "user error" comment haha... if only there was a rotation during medical school where we learned the things that really matter! Perhaps I'd have better luck if this was a broken bone.
I have driven in the other modes but now that I think about it, I haven't returned the car to wet mode, which was the mode I was in originally. Will try this later today also. Thank you!!
RTFM?
Maybe too simple: you need to keep pressing the dash button to lower the spoiler - quick tab will not do anything. Also, you say its in "intermediate" - base C2's have only one spoiler position - to my best knowledge.
I appreciate the response. Despite the post above, the manual was actually my first stop. I've done both the push and hold and the quick push methods as listed without success. The reason I keep saying intermediate position is that I did get one message on my dash that flashed then immediately went away that said something along the lines of "your spoiler is in the intermediate position." This was after my very first attempt at lowering it while the car was stationary. No other mentions of errors or any dash or PCM indications. I'm sure jlegelis will educate us both on spoiler positions for C2s, clearly this is out of this old swamp rats wheelhouse.
I think "intermediate" here is the "eco intermediate position" that the wing deploys for minimizing fuel consumption.
The additional Eco intermediate position is completely new. This spoiler position creates the lowest aerodynamic resistance, thus minimizing fuel consumption.
OP: Do you have a sunroof? Generally when you open the sunroof and drive on the highway, the spoiler deploys higher than normal. Try driving it open on the highway and see if it deploys higher (you should be able to see it in your rear view mirror). Maybe it would reset itself?
