Lowering a 992 GTS with CL Wheels
#33
#35
Another vote for KW HAS kit here, as I have it on my S and love the way it looks/rides.
Re the sunken wheel look: At the height @vic55 is set at, I think it looks great. Doesn't look sunken to me, more like an RS factory type stance.
Whoring out a pic of my car on HAS even though it's not CL:
#36
You can use the Bilstein EVO SE suspension. I put them in my car and the ride and drop is perfect.
My car in a turbo with 5 lug but the same suspension will fit in your car as well. It's surprising how aggressive the stance is on my car with the Bilstein set up. They really got everything right on this kit. I am using a 325/30-21 on the back and a 265/35-20 on the front with a 14mm and a 7mm spacer.
The front lift allows me to clear every driveway easily still.
I just took out a set of Height Adjustable Springs from a customers car to replace them with the Bilsteins. It is a night and day difference in ride quality between the two.
It comes with shocks as well in this kit. The rear shock in the FAL version is a fully threaded shock body. They also install using your factory electronics. It is a plug and play fit because Bilstein is also OE supplier for the 992.
Link to-
992 CARRERA SUSPENSION - World Motorsports
Link to-
#38
Link to-
Link to-
#39
Basic Sponsor
If you are located in the LA area we can easily do it for you. If you live far away we can help wak you through any questions with the install.
WORLD MOTORSPORTS
2170 W 190th Street Torrance, CA 90504
(310) 533-8900
- Akrapovic - BMC - TechArt - H&R - By Design - AMS - CSF - Kline - NGK - TiLugs - HRE - M Engineering - ID Injectors -
FULL SERVICE INSTALLATION FACILITY - STATE OF THE ART WIND TUNNEL DYNO - ECU TUNING
WORLD-MOTORSPORTS.COM
(310) 533-8900
Returnofthemac (04-04-2023)
#40
@Staff@WORLD Bilstein is saying this EVO kit is not compatible with the GTS suspension. I'm curious, does your Turbo have optional SPASM (i.e. identical to GTS) or just PASM (i.e. unique in the lineup)? Does the damping of the EVO feel similar to or more firm than stock?
#41
Basic Sponsor
Jeahbladejeah (04-04-2023)
#42
As a dealer, do you happen to know the spring rates for the EVO kit?
#45
Are the spring rates for the KW HAS spring rates comparable to the sport PASM found on the GTS?
i want to lower it, but don’t want to go softer than the factory sport pasm springs
