Removal of options on newly submitted 992 builds?
This is a question to people submitting new 992 builds in the last couple of weeks or so. Have you run into the issue that an option you selected is not available due to supply change issues? i.e. You submitted the build and your dealer said that they had to remove something? (Other than PTS, which I know is no longer available on 2023's)
I'm asking because I caught one error in my build that's set to lock in a few weeks, but I'm nervous about resubmitting if it means I might lose other options. My SA seemed to indicate that any changes are risky at this point.
If your build hasn't locked and it's a removal, not an addition, I don't think it's much of an issue. The only thing that would delay the build is requesting an addition that's been stop ordered. I had to remove a few items ahead of lock date, then my lock date was pushed back and I managed to add in everything that was previously stop ordered (Aerokit, Bose, and Race-Tex sun visors) before the new lock date. I also removed FAL. For such a high-cost item, I wouldn't be afraid to ask! Good luck.
electricborn (01-25-2023)
The following 2 users liked this post by 22992:
electricborn (01-25-2023),
TimD (01-25-2023)
This just happened to me with PCCBs. I confirmed myself while at the dealer that my SA had submitted PCCB as part of my build. After it went V200, I noticed on TYD that PCCB was missing. Dealer added it back again but Porsche denied it the second time. Now I have to decide if I keep the allocation or punt until they're available again.
What's the error on your build? If you're removing something then as far as I understand it you should probably be fine.
Two years on the waiting list and I got THE call (less than a week after I plopped $35K on a new PP, I might add!) that my allocation for a Turbo was in and would I take it? I submitted a build and was told that PDCC was not available. 2 Questions... 1) Is my allocation for my original SPECIFIC model or can I up it to a Turbo S or drop it to a 4S? 2) Is not having PDCC a big deal or would you walk away?
Thanks Freunden!
Thanks Freunden!
Thanks Freunden!
Thanks Freunden!
The following 2 users liked this post by breny4104:
Will Tell (01-24-2023)
This just happened to me with PCCBs. I confirmed myself while at the dealer that my SA had submitted PCCB as part of my build. After it went V200, I noticed on TYD that PCCB was missing. ...
I realized I checked the SPASM box when I really just want PASM. I plan on a lot of long road trips with my 4S Cab so I'd prefer to trade comfort for stiffness and style. Kind of a big deal for me personally.
But I have PDCC in my current build which is an even bigger deal and my rep said that has been dropped on some newly submitted builds. So I may be stuck.
You'll want to search the PDCC threads about whether or not it's a requirement for you. Basically it levels out cornering and improves ride comfort somewhat. For me, it was a must have and I rejected a couple of used 992 options because they didn't have it.
PDCC is exactly the thing my rep said isn't being accepted with newly submitted builds. My current build, submitted in Dec, has it, so I think if I resubmit I lose it.
Thanks for confirming with
Thanks Freunden!
Thanks Freunden!
Thanks for confirming with your experience.
I personally think you will be just find with SPASM the ride is still excellent.
I had the black porsche side decals removed by Porsche like 2 weeks ago, unavailable until 2024 they said.
Have my order in Sweden, at least it wasn't an essential option that was removed and will be easy to rectify later if I wanted to.
Thanks electicborn! I'm going to research the PDCC threads but what do you mean by "...improves ride comfort somewhat..." I live in the NYC area and roads can be pretty abysmal. My nightmare is having an overly stiff ride to where the fillings get shaken from my head or, worse, the car gets shaken to pieces. That's what really impressed me with my Panamera Turbo vs AMG vs M... The air shocks were a thing to behold and I've never had a worry diving the East Coast crust. My point is that I'll always choose the more compliant suspension option. Given what PDCC is supposed to do I would have thought that it makes the car stiffer. Your answer implies otherwise...
See this excellent summary by @chuck911 here: https://rennlist.com/forums/992/1164...l#post16163997
Porsche's official press releases also describe how ride comfort is improved: https://www.porschelouisville.com/ho...-control-work/
