Help with Chrono Color Change
Old Jan 8, 2023 | 02:16 PM
Shogunade's Avatar
Shogunade
Originally Posted by Macboy
If people just specced there cars a bit better we wouldn’t have need to go through all this trouble. Of course some people hate yellow. But don’t order a yellow car then
Huh? I didn't see OPs instrument cluster but I'd bet he has a yellow tach or is planning to DIY that in the future. They just saved themselves $350 and gets to say he DIYed something.
Old Jan 8, 2023 | 02:25 PM
Macboy's Avatar
Macboy
My bad sorry. I was just speaking in general where I notice a lot of cars are not up there. So I always feel the need to change minor things like this to make it perfect. The chrono dial is one of the few that can be retro-fitted by the dealer. They don’t like the job though. I like it when people DIY but it’s not a very costly option on the car is it?
Old Jan 8, 2023 | 04:55 PM
Shogunade's Avatar
Shogunade
$350. It's crazy how quickly I can decide to fork over $150k plus, but agonize about a $420 option.
Old Jan 8, 2023 | 09:59 PM
Andy2021's Avatar
Andy2021
I’d like to see the process to change the gauge face for the 911 992 Dashboard Tach: https://www.ebay.com/itm/20368420059...mis&media=COPY
Anyone tackled this one yet?
Old Jan 8, 2023 | 10:11 PM
Shogunade's Avatar
Shogunade
Yup Username Siberian did it and had some photos of the process.
Old Jan 8, 2023 | 10:31 PM
Andy2021's Avatar
Andy2021
Yup
Came out great! What resource did you use to help understand how to disassemble and reinstall the tach?
Old Jan 11, 2023 | 07:29 PM
GoCards67's Avatar
GoCards67
I just did this and had a few things to add. First, go into the car menu and in Settings/go into Addition instrument" and disable the clock. That will make the hand go to 12:00 and make it easier to re-align later. To get my clock out after popping up the dash trim, I used a 17mm socket to get the clock out but after several attempts to turn counter clockwise as mentioned above, mine was definitely clockwise to remove. The wire attachment is very easy to remove once the clock is out. Once out of the dash, to separate the clock halves, remove the rubber gasket, then insert a small screwdriver or something flat to pry around the area with the indentations noted by the red circle. I think there are 3 of these indentations. Keep working your way around. When the halves come apart, just pay attention to the orientation of things. It will seem logical when going back together since there really is only one way to reassemble. The hand came off easy for me with the spoon method. The most stressful part is getting the new plastic face on. It must be "snapped" around the inner ring. As mentioned, it will fight you and you don't want to crease it. you will see the alignment holes and you can rotate the new face to line up. Look at how the posts of the black outer ring align with the aluminum marker ring below and piece together. Put the hand back on at the 12 position. I used compressed air and MF cloth to clean the dial and the back glass and reassemble. Hope this helps a bit!!
Old Jan 11, 2023 | 11:37 PM
Andy2021's Avatar
Andy2021
Thanks. Which way do you turn the wrench when looking at the rear end of the clock where the socket is for the allen wrench? Also, did you change the guage face for the tach?
Old Jan 11, 2023 | 11:41 PM
GoCards67's Avatar
GoCards67
Looking at the back of the clock, you go clockwise to release, and counter to tighten. Also, its a socket wrench. No Allen wrench needed here. And I just did the chrono clock. Not sure I am brave enough to tackle the gauge face.
Old Jan 13, 2023 | 12:28 AM
Vista6019's Avatar
Vista6019
Originally Posted by Vista6019
I love this and would be helpful if there were other install pics
Looks great! Where can you purchase just the face?
Old Jan 13, 2023 | 01:47 AM
Shogunade's Avatar
Shogunade
ebay
Old Jan 13, 2023 | 08:42 AM
eagle1960's Avatar
eagle1960
Originally Posted by Shogunade
ebay
Link posted in the thread.
Old Jan 14, 2023 | 12:04 AM
Vista6019's Avatar
Vista6019
Got it. Thanks very much
Old Jan 14, 2023 | 10:27 AM
shrimp money's Avatar
shrimp money
Saved $350 if you successfully complete the task without breaking something.
Old Jan 14, 2023 | 02:58 PM
Shogunade's Avatar
Shogunade
Risk reward.
