c2S vs GTS SPASM
If you opt for sports PASM in a C2S and the GTS (whis is standard I assume) are they lowered the same 10mm? It just seems the GTS tire gap looks lower then a C2S in some pics. I was looking at a friend's GTS but didn't have a S to compare.
GTS comes with SPASM, C2S SPASM is optional. Same option on both cars, so the ride height on a SPASM-equipped C2S is the same as a GTS.
The following 2 users liked this post by jzra:
AventurineMan (11-26-2022),
zachr (11-25-2022)
Thanks.,.....it's just when I look at the ground clearance on the front bumper as well at the front tire gaps.....the GTS seems a lot lower then just 10mm.... Some kind of optical illusion? It literally has turbo suspension I thought
The optional non-Sport PASM on the GTS is the same as the Carrera base PASM.
So the conclusion is C2S With SPASM is still gonna be a hair higher then a GTS
On the Porsche models page you can click on "Technical Specs" on each model and it will list ground clearance and also PASM vs PASM Sport. The S comes with regular PASM standard (and PASM Sport 10mm drop is optional) which lists PASM clearance at 4.9" and the 911T and GTS with PASM Sport list ground clearance at 4.5" (a 10mm drop standard, but on the S there's an optional 10mm ride height increase). So keep in mind that if you are looking cars at a cars & coffee, you need to know which suspension each car has.
