My Porsche App indicates my car should have a front tire pressure of 35 psi and rear tire pressure of 45 psi. I have read different recommendations elsewhere. For a warm weather location (South Florida), is there a preferred tire pressure? I have a 992 GTS Cab with the Goodyear Eagle tires if that makes a difference.
I use 33 front 38 rear which is full load comfort pressure. You’ll need to make the change in your PCM.
Isn’t full load and comfort two different pressures? I just looked in my manual and now I’m going to check again. I’m 32/38 (have turbo size rear tire 20/21) on my winters and it feels great.
Edit: You have to state if they are winter/summer and 19/20 or 20/21 for the correct pressure.
The advice pressures of opening post are for GAWR's fully used and maximum technical carspeed. That last is verry high for porche.
I determined that if 90% used of the loadcapacity calculated for the pressure for 99mph( 160kmph) that then comfort and gripp is still acceptable.
So if you can hold yourselfes to that maximum speed, and wont go over it for even a minute, I can calculate a pressure for those GAWR's so still fully loaded, wich you seldom use.
But can also make a pressure/ axleload list for your tires ( different front rear).
Then you " ONLY" have to determine the axleloads in your use, and search them back in the list.
Succes with determining those axleloads, the most tricky part in it all, and your respocibility.
Give maxload or loadindex, XL or not, and speedcode, or give sizes, so I can google.
Made spreadsheet to make those lists, in wich I can change the percentage used, per axle or tire, and make list for higher speed. Yust write how you want it.
Been using 32/38 recently and I find it to be ideal.
Agreed. 10k miles in and 32/38 are my preferred pressures.
Although I keep losing air in the rears. Ever since tracking the car. I’m losing about 5psi in a week, then it stops. Now that temps have dropped its speeding up a bit.
When I bought my targa 2weeks ago, this is what my dealership put me on my tires. Crazy!
I deflated it just now to 34/39. (+1 from 33/38 cos it’s winter!) and set up as fully loaded and comfort pressure in my pcm.
