Finally a solution for the Porsche Lithium Battery
Apparently there is a way we can now bypass and get our cars to use other lithium batteries instead of the Porsche Batteries which has no ETA .
First we have to replace the Porsche ground cable with the 992 AGM battery one ( 992915181) part number .
We can then install the Lite Blox battery/ other lithium along with our IBS.
The IBS will be connected between the wiring harness and the new ground cable.
At the end the car shall be coded to a AGM battery instead of the lithium one.
https://www.lithiumax.co.uk/forum/news-and-events/porsche-pff-event-stuttgart
https://en.liteblox.de/shop/lite_blox-lb78xx-lightweight-battery-for-oem-industry/
anyone has done this ?
I am planning to do this .
The following 2 users liked this post by kgb_kgb:
porscheprestige (09-01-2022),
PTSUltraV (09-01-2022)
https://www.lithiumax.co.uk/forum/ne...vent-stuttgart
https://en.liteblox.de/shop/lite_blo...-oem-industry/
kgb_kgb (09-01-2022)
This is interesting, and thank you for sharing.
Any chance you can you share where you got the information?
@Antigravity , interested in your thoughts on this, if any. I recall the following from another post of yours:
https://rennlist.com/forums/992/1241...l#post17306301
Is this the sort of workaround you imagined, or have you guys had any other thoughts on this recently?
if there is a work around to use the AGM Battery then you can also use our Antigraivty Battery since you won't have to PLUG_IN the battery and our battery swaps out fine in the a Lithium or AGM Charging profile. The fact is Tom at Europen Auto Source just developed a work around for the BMW M4 Battery to use our Lithium Battery by swapping out some parts for the IBS and they have a kit being made. So I am assuming there should be a work around.
kgb_kgb (09-02-2022)
This is what I was hoping from the Porsche community, as with BMW, Mercedes, communities….if there’s an issue (not just the battery, but other things such as activating the matrix lighting, etc), and enough people want it fixed, 3rd party solutions will begin to surface.
If this works, could be a game changer, for being forced to use the Porsche Li battery.
Yes. The issue then is, what does the on board software do when it has no response from the BMS unit?
The ground strap does sound like a potential drain culprit and reason an "advisory" was issued concerning this.. I'm just curious as to what happens when the main procedure calls BMS subroutine and doesn't receive a reply, unless the new battery from a VAR provides a "reply" and if so beyond simply "saying" "I'm here" will it also be able to send other system messages...
There will also be some PIWIS coding in VOF etc. to tell the system you're now an AGM. Will this cause issues for those with RAS? Yes RAS folks in years prior had AGMs but many more gizmos were added requiring added umpf - ergo LiFePO4 became a "must". Could this cause an issue or is it only for those with RAS + other options?
We need more information beyond replacing a ground cable IMHO.
Keep us posted please!
siberian
siberian
null (09-02-2022)
My understanding is that lithium batteries are charged at 13.4V and AGM batteries at 13.8V. If you convince the car you have an AGM battery fitted when really it's a lithium one then won't the car ask the alternator to charge it at the wrong voltage?
Not if your descriptive (VOF etc....) the car is described as an AGM. As I mentioned there's more to this than simply swapping out a cable etc.
Let's not sink the ship in our rush to find a solution ...
siberian
siberian
You first.
