drove the 992 about 7-10 miles with 1.5 Q low oil.. should I be worried?
As the title says... it came up on the 1 year change and I gave the shop 7 quarts of the C40 spec ESP 0w-40.... turns out it needs 8.5+ .. of course, the car doesn't tell you it's low for a bit.. the engine oil level needs a certain time/distance driven before it registers ... but once it did, it alerted me .. "Oil Level Critical" and it was in the red.. Oil pressure was fine, and temps were good... no issues.. am I over thinking this?
I solved the issue by adding another quart and half and it's not right in the middle.
Didn't drive it hard, just normal.. max maybe 3500rpm getting on freeway.
992Sam (08-31-2022)
Yes. Your piston walls are scored from lack of lubrication and you should get a new engine. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Seriously though, you are fine.
992Sam (08-31-2022)
7-10 miles down 1.5 quarts should be fine. I wouldn’t worry about it.
Received 2,647 Likes
Your engine is just fine. 1 1/2 Quarts low on an oil sump the size we have on our 992’s is nothing to worry about. Top it up, go forth and sin no more.
992Sam (09-01-2022)
Received 2,842 Likes
Out of interest how many miles on it now?
992Sam (09-01-2022)
992Sam (09-01-2022)
Hopefully he did it himself...it's called "bonding"
siberian
siberian
Bluehighways (09-01-2022)
Dealer was $2250 ... my independent (it wasn't his fault as I told him to put 7 quarts in it)... $1300... I trust his mechanic, veteran Porsche dealership trained and has worked on 991.2's a lot (similar motor) .. 10x over the random quality experience I've had with my dealer in the past.
