Hi all.....have had my 992 for 8 months or so now....put on a whopping 1100 miles. Love it....
Everything has been great until yesterday. I started my car and received the following error messages:
1. Left Low Beam Error, Right Low Beam Error
2. Check Right Front Daytime Running Light or Parking Light, Check Left Front Daytime Running Light or Parking Light
i called the dealership and they thought it could be something that just goes away. While i do have low miles, i drive at least 2x a week. No MODs or any external adds/chargers/etc.
I saw some post about this a few years back. Does anyone have any ideas or suggestions? Maybe pull out the fuse and see what happens????
I have a MY 22 delivery in Sept. Can you describe how to use and which tender to use. My C8 is dead simple to plug into frunk to tender. not clear on which tender to use for C2 cab not RAS
I received that same error code when I first purchased the car. The error occurred on only that one occasion. I basically shut the car off, waited 10-15 seconds and then restarted the car.
thanks!
Can we assume you checked the lights indicated? Were they operational compared to the RH side?
thanks!
I have the same error and the dealership is replacing the headlights, only 200 miles in my new gts
