Battery Tender for 992
Looking for opinions and advice with which battery maintainer is best for winter storage.......Deltran 12v Battery Tender vs. CTEK vs Porsche Charge-O-Mat....or other preferred options.
The 992 doesn't have a cigarette lighter for an easy hook up. And I'm not yet sure if the leads are big enough on the battery tender attachment.
(Sorry if you saw this post in the general discussion post already....didn't notice the 992 subcategory in this Water Cooled section.)
Received 5,410 Likes
CTek is a quality product at a good value.
Sajan (01-16-2020)
I use a Deltran Battery Tender on my 2019 Carrera T. Very simple. Open the front hood. Remove the black trim cowling, connective the negative to the grounding post on the drivers side and the positive to the red post on the battery. Route the wire through the vented slots in the black plastic, wire exits up toward the windshield where there is a cutout area and carefully lower the hood and plug in.
Works great - assume it would be very similar on the 992.
Potsy (12-01-2019)
Does you 992 have Rear Wheel steering? If so you have a Lithium battery and need a lithium specific tender.
I bought the Porsche brand unit, as it comes with a cigar type plug, that can be plugged into the interior of the car. On the passenger side, in the foot well, left side, way up front, there is a socket where the charger plugs into. I haven't used mine yet, but plan to this month.
Is there a specific CTEK model # that someone has experience with for the Li ion battery? There is a recommended current maximum for most Li automotive batteries and a lot of options on most battery tender websites.
I am using the CTEK Lithium XS since last month when weather started to get 'orrible . I hard wired in the eyelets on battery , so when I put car away just pop one side of the cover , push on connector and run the cable thru gap of the closed front lid ( wire has enough room ) I considered pulling through the cover but didn't want live end on the "wet" side of the car ( even if it does have a rubber seal cap)
Takes a minute to pop the lid, unplug, re-seat cover and close lid to go . Glad I did now, as I only really use at weekend and if car is put away and then the weekend is a wash, I don't have battery anxiety when I end up not using ....while systems like the Porsche VTS gentry drain my battery in the cold.
got2go (12-06-2019)
got2go (12-06-2019)
Thanks to you and PBM for the help.
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
I wouldn't bother with the Porsche branded CTEK, it really is an obsolete 4-stage charger by all measures that is simply overpriced especially when CTEK chargers around the $80 - $100 mark are all great value for money in comparison and have better features and capabilities.
Charger
for easier charging setups
Cigarette Socket Plug & Play connector which matches all of their chargers with the "Comfort Connect" setups
NigelPlays (01-14-2020)
Is it bad form replying to my own post lol?
Anyway, Service Manager at my local dealer has confirmed that ALL 992s he's received/PDI'd - whether with RWS or not, have Lithium batteries. Nice "bonus" for Canadian (and Russian et al) buyers.
This is interesting. The 9Y0 Cayenne was Porsche's first foray into Lithium Iron (LiFePO4) batteries. Note the battery is not Lithium Ion, the type that resides in many laptops and mobile phones. LiFePO4 batteries are much more stable; far more expensive; and much less apt to catch fire in the garage and burn your whole damned house down.
If the 992 comes standard with this type of battery, here's hoping the battery-protection circuitry present in the 9Y0 to keep the four-figure thing from being drained down (and damaged irreparably) by the heavy at-rest electrical draw in modern cars doesn't misfire badly in the new 911 like it does in the Cayenne. There have been a relatively large number of completely dead, no-start conditions in the 9Y0. When that happens, you can't just jump the car and get it running again. A gateway unit under the driver's seat needs to be reset, which of course in fine Porsche fashion requires the entire seat to be removed. Hello, flatbed tow-truck from the steakhouse where you'd taken your family out for a nice dinner. Some were considered unfixable by PCNA and resulted in buybacks. If you're interested in reading, go here: https://rennlist.com/forums/cayenne-...-to-start.html.
As for ours, no problems after a year. So far we've been nothing more than lucky. I would personally prefer a nice, heavy, old-tech 12V lead-acid battery sitting in my 992 when I take delivery. That probably won't happen, from what you fellas are reporting.
Porsche seems to be a great company to reinvent and ruin perfectly operable, cost-effective technologies. See simple ***** and buttons; cheap, reliable batteries; and in the case of PSCB, reasonably quiet ultra-performance brakes. It's like they've never heard of long-term QA and testing.
vg247 (02-05-2023)
