18 Way Seats
Old May 5, 2022 | 09:49 PM
356Fan3's Avatar
356Fan3
Default 18 Way Seats
Not to truly complain but curious. I have 18 ways, and experienced 14’s and 4 ways in the past with very few issues. On long trips the bolster on my left leg feels stiff and becomes uncomfortable (I do have ventilated seats?). I’m just at 2600 miles. Anyone experiencing discomfort and if so have your seats loosened up over time,
Old May 5, 2022 | 10:00 PM
Riddleric's Avatar
Riddleric
I have 18 way seat and it’s very stiff. a bit painful and uncomfortable for long distance.
Old May 5, 2022 | 10:47 PM
Bluehighways's Avatar
Bluehighways
With the 18 Way Seats one can adjust the side bolsters in and out. I may be "taking coal to Newcastle" as it were, but have you made sure the bolsters are all the way out?
BillyX's Avatar
BillyX
I have the the 18-Way Sport-Tex seats, so no ventilation. My morning commute leg is 45-60 minutes. The seats are still very comfortable at 9,000 miles. My only complaint is the incomplete electric steering column.
Old May 5, 2022 | 11:24 PM
AlexCeres's Avatar
AlexCeres
It’s not the seats. It’s you. Seats are a very personal preference. I find the 18 way more comfortable than 14 and my wife does not. I also think the buckets are very comfortable to be in, although a huge pain to get in and out of. But no one can tell you about the seats. There’s no correlation to height or weight.
Old May 6, 2022 | 12:33 AM
EZ E's Avatar
EZ E
Just ordered a 2022 GTS and went with the 14 ways seats. The 18 way seat hurt my back after driving the car for an hour. If you track it get the 18 way.
Old May 6, 2022 | 07:57 AM
detansinn's Avatar
detansinn
I put more than 35k miles in my 992C4S 18 ways over 2.5 years. I found them to be extremely comfortable. My wife declared them to be the most comfortable of any of my sports cars — she wasn’t wrong. I am 5’9”, 180lbs.
Did you play with all of the adjustments?
Old May 6, 2022 | 08:27 AM
Tobeit's Avatar
Tobeit
Let me know if you are so uncomfortable and want to switch to 14 way seats ..and I am serious.
Old May 6, 2022 | 08:38 AM
356Fan3's Avatar
356Fan3
Good morning, I believe I have tried every adjustment at this stage. I am 5'9'', 175lbs. I do have a manual (only manuals in the past as well without issues). It could be the seat leg positioning and the clutch. Thanks again for the replies.
Old May 6, 2022 | 10:18 AM
Keadog's Avatar
Keadog
I just did 9+ hours with two stops for gas in my 18s, also with a MT.
I thought they were most comfortable. And the vent seats worked quite well.
Person preference, of course.
Old May 6, 2022 | 12:34 PM
aggie57's Avatar
aggie57
I have 18-ways with MT, and am 6’3” / 250lb. They’re comfortable to me; I have the back and squab bolsters fully out. To be frank at first I wondered if they’d get uncomfortable on a trip but I’ve done a couple of 500+ mile days and they’re really good, even though I’ve always suffered from lower back pain.
What I do is save 2 settings, one more upright and slightly closer to the wheel (which I use mainly around town) and the other more relaxed so slightly further away from the wheel and lower. It’s really easy then to switch. Of course you can do that with 14-way seats as well.
Old May 6, 2022 | 05:46 PM
Tedster's Avatar
Tedster
I have the 4 way plus on my C2S, and it is basically the same seat as the 18 way, minus the added adjustability and motor weight. It is definitely more sporty than the 4 way and 14 way seats which share the basic design and have shorter seat bolsters and also less shoulder bolstering that the 4 plus and 18ways.. I have also had the sports buckets and found them comfortable on long trips. Egress is tougher though. 5'11, 200 lbs. For some reason my Boxster 718, which had the 14 ways made my lower back hurt after driving longer than one hour or so. It also had PDK which made it easier to let go of.
Old May 6, 2022 | 06:19 PM
Keadog's Avatar
Keadog
I was considering a 981 Spyder with buckets back when cars like that sat on the floor for more than 32 seconds. They seemed remarkably comfortable once you got in them. Getting in and out was another story though.
Old May 6, 2022 | 07:11 PM
Litigator's Avatar
Litigator
This is super helpful - thank you!
Old May 9, 2022 | 02:41 PM
fstezaws's Avatar
fstezaws
I put 10k miles in 18-way seats on my first 992. I was hesitant to get 14-ways, but overall they are super similar. After logging 1000 miles in my 2nd 992 I find the 14-ways to be a little more comfortable, where the 18-ways hug you a bit more. Both are fantastic and very supportive, but the 18-ways are definitely a sportier feel.
