Diagnose my tread wear?
Old 04-27-2022, 12:00 PM
alreed
8th Gear
alreed's Avatar
Default Diagnose my tread wear?
Hey all! New owner and totally new to driving on a track. I'm on a 992 C2S and started last year on the OEM tires (Pirelli's). Replaced the rears earlier this year and now I think the fronts are wearing out, I think in a normal way but would love to hear people's thoughts about what's going on.
This is the front right which I had off.
Front left (which is sill on the car in this picture) so they're not as good:
Old 04-27-2022, 12:47 PM
drcollie
drcollie's Avatar
Received 4,193 Likes on 1,480 Posts
HA! Welcome to track days....that's all normal if you push a car hard on the track. Outsides always wear faster than insides as you are running stock camber and toe. In the middle of your tire that's not wear per se, its your tire picking up rubber from the track when hot, and it stays on the tire when it cools off. As you can see, street tires get chewed up pretty fast in track environments. What us old track junkies do is run two sets of wheels and tires so we are not chewing up our good street tires. Save the worn ones like you have above for track days and run them to the cord. A more advanced option is to get off street tires altogether and run more dedicated track tires like Cup tires or R-Comps on your second set of wheels (track wheels don't have to be pretty -the more banged up they are the faster you go).
Tires and brake pads are consumables when you start tracking your car. You can get 8 to 12 events out of a set, depending on the track, the surface and your driving style.
dhirm5 (04-27-2022)
Old 04-27-2022, 02:07 PM
ipse dixit
ipse dixit's Avatar
Received 11,776 Likes on 5,141 Posts
What's going on?
Nothing, except normal high performance use.
detansinn (04-27-2022)
Old 04-27-2022, 02:29 PM
CodyBigdog
CodyBigdog's Avatar
Received 2,246 Likes on 1,275 Posts
Curious - How many street miles on the tires, and how many track miles (or track events) ? Do track a lot?
Old 04-27-2022, 02:31 PM
detansinn
detansinn's Avatar
Received 8,145 Likes on 3,010 Posts
Totally normal. Welcome to properly using your tires.
Old 04-27-2022, 03:17 PM
aggie57
aggie57's Avatar
Received 2,876 Likes on 1,516 Posts
Welcome to the fun part of owning a 911, and as others say that looks pretty normal. Worn tires like this are actually pretty good for track use, well these are possibly a little too worn for a full day but either way new street tires on the track can get chewed up pretty quick.
Old 04-27-2022, 03:34 PM
alreed
8th Gear
alreed's Avatar
I got the car used, but pretty sure they're original so about 5k "normal" miles and 6 tracks days of about an hour each. Being a novice, I'm guessing I didn't thrash them toooo hard...
Old 04-27-2022, 03:35 PM
alreed
8th Gear
alreed's Avatar
So the consensus is - these are looking normal (they seem to be wearing way more in the middle?) and they've still got some life in 'em?
Thanks again, everyone. Really appreciate the advice.
Old 04-27-2022, 04:01 PM
drcollie
drcollie's Avatar
They are not really suitable as street tires, because you are down to the wear makers, which will make them quite hazardous in the rain and prone to hydroplaning. They are fine as track-only tires, however. If you just want to run one set of tires and wheels, then you should get replacements soon.
The following 2 users liked this post by drcollie:
aggie57 (04-27-2022), detansinn (04-27-2022)
Old 04-27-2022, 06:24 PM
aggie57
aggie57's Avatar
Yeah, looks like a bit more wear in the middle; what hot pressures do you run?
Old 04-28-2022, 10:06 AM
garthg
garthg's Avatar
Diagnosis: expensive hobby.
Old 04-28-2022, 11:24 AM
CanAutM3
CanAutM3's Avatar
Received 1,329 Likes on 622 Posts
I see tread shredding in the middle of the tires, which usually is the result of overheating and potentially caused by over inflation. What hot pressures were you running?
Old 04-28-2022, 11:49 AM
Richard_Wallace
Richard_Wallace's Avatar
Received 1,690 Likes on 754 Posts
I was going to reply with the same question, I am betting that the hot temp PSI is running a little high (ie upper 30's low 40's). For the OP, once you get the tires up to temp, you can deflate down to 30/32 front - 32/34 rear and you will get less wear in the middle of the tire. (or start a little lower - though you may throw a low PSI sensor until up to temp).
But honestly not that bad. If you are going to track somewhat frequently, likely a new set of tires every year (or 2 times per year) will be in your future. On a few of my other cars, I just bite the bullet and get a dedicate track rim and tire set and have my road tires for another. Makes swapping easy, inspection, and swapping out new rubber easier when needed.
Old 04-28-2022, 11:58 AM
CodyBigdog
CodyBigdog's Avatar
Wow. I’ve had Pirellis before and know they have soft rubber, and known for short lifetime (on the street)…I’m coming up on 4K miles (street use, only). I see wear, but nothing like your pics, so I will presume, much of the wear is due to the track.
Old 04-28-2022, 12:21 PM
TJ74
TJ74's Avatar
Not to hijack the thread, but I am a first time Porsche owner, C2S, getting ready to track my car. My previous car was a C7 Grand Sport. Corvette has a track prep section in the owners manual with recommended cold tire pressure (28psi) for all four tires. 30psi was the recommended street pressure. At Ron Fellows they said to aim for 34-35psi hot.
On the Porsche for the street I am running 29/32. Richard Wallace recommended to start at these pressures, my question is what temps are you looking for when hot? I was going to shoot for the same 34-35 all around as in the Corvette? Maybe since front & rear pressures are different I should look for a similar split, 6-7psi rise, 35-36 front & 38-39 rear?
Quick Reply: Diagnose my tread wear?
