992 Center Console Removal
QQ for those that have removed the center console trim, specifically the U-shaped trim (part 6 in the diagram above). Is there an easy way to pop it out (say with the plastic / generic trim removal tools) without disassembling the center console entirely? TIA.
Received 2,687 Likes
Anyhow, beyond these two pieces, everything else has little screws at one point or another, that need to be removed; often with snaps as well as being a layered assembly.
Ex: To remove Part "C", Part "B" must be removed first. Unfortunately Part "A" must be removed prior to removing Part "B" and the screws that allow you to remove part "B" are not visible until after Part "A" has been removed.This is precisely why Part "B" seemed stuck when you tried to remove it before removing Part "A". Seriously this console is layered like this. Take you time and you'll be OK.
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/800x589/console_panel_view_lr1_c2439c3bba63f7fdb0215d01ac434eba2f801325.jpg)
I forced it back on. It took massive effort and felt like I was going to break something. I think there's probably a much easier way to disassemble it further and re-intall the buttons after disassembly.
