992 CS Alignment recommendations
Hi All.. Are there any alignment threads here in the 992 section. I looked and searched and found nothing. Even Googled. Does no one play around with their 992 suspensions?!
I think it depends on what you want out of the car. Are you looking for better handling on the track? Better tire life? Mostly street driven? The factory specs work well for all around driving. It is worth checking to see if the car is actually aligned to factory specs, however.
Look at the 991 forum.
I brought mine in for its first annual service and told the SA while they had it to check the alignment because I recently started getting a slight steering wheel shake at 80+ on the highway (ahem, on those rare occasions when I have to pass someone at high speed) and sure enough when they put it on the alignment machine it was previously way out of the green zones on the print-out they gave me when I picked it up. However, while it's better now and I know the alignment is perfect, it still doesn't feel totally smooth at high speeds (80+) so I called back and the SA suggested we do a high-speed wheel balancing, which I'm taking it in tomorrow to do. When I had the winter tires put on, I don't think they did a great job fully balancing the wheels.
On the print-out from the alignment you can tell that there are factory determined parameters for caster, camber and toe so if you want to play with any of those you probably couldn't take it to a dealer to have it done. Same way every time I bring it in they pump the rears to factory suggested 45psi and my teeth are always chattering on the ride out.
On my previous 997.2 and 991.1 C4s cars the alignment on the cars from new was quite a bit off from the "factory specifications" In fact both had less front negative camber and more rear camber than spec. That led to significant understeer. Proper alignment transformed those cars.
My new '21 C2s actually felt pretty good on track (for a "street" car) but took it in to my local independent who does a lot of track set up for 911s. Interestingly, the 992 can actually get about 1.8 degrees negative on the fronts where before on the 991 it was about 1.4.
He adjusted the front to that max and balanced it with 1.8 on the rear (which was pretty much where it was from the factory). The only oddball thing on my car from new was that there was small toe out! on the right rear.
Hope that helps.
Hope that helps.
The following 3 users liked this post by 1100S:
got2go (01-10-2022)
alignment never causes vibration,it has to be something that rotates. the most likely is wheels.
theoretically a louse tie rod end or bad ball joint could cause some louse felling and slop in the steering but id bet against it in a new car. carl
drcollie (07-10-2022)
