Lithium battery charging
Old 12-07-2021, 11:52 AM
Bassman51
Bassman51's Avatar
Default Lithium battery charging
I got the Porsche battery charger and set it up today to see if it works. I have the 12V end plugged into the footwell outlet and mode set to “Lithium”. I locked the car per instructions. None of the indicator lights go on. What am I doing wrong?
Old 12-07-2021, 12:15 PM
CodyBigdog
CodyBigdog's Avatar
Received 2,228 Likes on 1,262 Posts
There are a number of threads on the exact procedure….but I think it goes something like this (?):
(1) Start car,
(2) Turn off
(3) Plug charger into footwell 12v port.
(4) Lock car
(5) Plug charger into AC outlet and select Li charging.
I believe you have about 15-30 minutes to plug the charger and activate before the cigarette port goes inactive.
If you want to bypass all this silliness, open the frunk, remove the protective covering over the battery and charge directly (ie connect directly to the battery). That’s how I do it, and I think it also has a benefit of charging quicker than through the 12v port in the foot well.
The following 2 users liked this post by CodyBigdog:
Bassman51 (12-07-2021), detansinn (12-19-2021)
Old 12-07-2021, 05:19 PM
Bassman51
Bassman51's Avatar
Default It Works!
@CodyBigdog Thanks a bunch - works as you described. I just ordered the clips to connect directly to the battery terminals.
Old 12-07-2021, 05:57 PM
dhirm5
dhirm5's Avatar
Received 1,455 Likes on 799 Posts
In all my years of ownership of cars that others plug in to trickle charge, I have never bothered.
Why do you guys do this?
Old 12-07-2021, 06:12 PM
CodyBigdog
CodyBigdog's Avatar
Ur quite welcome.
Old 12-07-2021, 06:25 PM
Bassman51
Bassman51's Avatar
dehirm5:
I do it because I've had my 911 batteries die on me a couple of times while sitting unused for several weeks in the winter. I've never had this many battery problems with any other car I've owned - American, Japanese, German. Only with Porsches - there is no substitute.
I'll be away skiing for a couple of weeks at the end of the year and a dead battery in a 911 (or other modern cars) is a pain. The battery is in the frunk, which can only be opened via the electric switch next to the driver's seat. Which is inoperative when the battery is dead. So you require a booster battery, which needs to be attached to terminals located in the fuse block in the driver's footwell, to open the frunk. So you can get to the battery and either jump start the car or replace the battery. It's a pain. As is this, but I find this the preferable pain.
Old 12-07-2021, 06:40 PM
dhirm5
dhirm5's Avatar
dehirm5:
Lol -- sorry to hear your troubles. Haven't had that experience.
Fishtaco (04-01-2024)
Old 12-07-2021, 06:42 PM
Bassman51
Bassman51's Avatar
Yeah, it could be my stupidity - doing something with the Porsche I shouldn't, or not doing something I should. Anyway, I don't go through the battery maintainer thing often, only when I know the car is going to sit for a while.
Old 12-08-2021, 08:36 AM
doug_999
doug_999's Avatar
Default All you need to know is here
https://rennlist.com/forums/992/1193...ell-992-a.html
Old 12-08-2021, 12:06 PM
BCA01
BCA01's Avatar
I have the standard/AGM battery but it's interesting that you say this because it does seem to take MUCH longer to charge than the exact same charger did on my 991.2. I thought something was wrong at first but it consistently takes a long time, so perhaps something is different on the 992. Both vehicles charged through footwell port.
I also notice on my 992 that after taking a drive, no matter the time/distance, the charger always starts from the 50% level and takes quite a while to reach the 75% level and finally the 100% level (I have the old Multi US 7002 with the 4 stages). On my 991.2, it would rarely even dip to the 50% level and would jump to 75% and 100% very quickly.
Oh well, I guess this is all normal operation on the 992. I assume if the charger shows 100% charged, the battery is indeed fully charged. But after ~2 months of ownership, I'm still not quite used to the difference from my 991.
Old 12-08-2021, 12:12 PM
Bassman51
Bassman51's Avatar
With the lithium battery and the Porsche charger connected through the footwell, the indicator lights started at 25% yesterday afternoon. I would be shocked if the battery was really that low. This morning it was 100%, and still lit up. I packed it up and will reconnect before I leave the car for couple of weeks.
Old 12-08-2021, 12:15 PM
CodyBigdog
CodyBigdog's Avatar
There’s no question in my mind, based on my experience, with my Li battery, that charging directly connected to the battery is MUCH quicker than going through the 12v port.
Old 12-20-2021, 12:10 AM
kgb_kgb
kgb_kgb's Avatar
any idea if we can use other brands, this batteries cost too much to replace
Old 12-20-2021, 02:52 AM
kgb_kgb
kgb_kgb's Avatar
any idea where i can buy a new battery or can i use alternative brands
Old 12-20-2021, 12:49 PM
siberian
siberian's Avatar
Received 2,300 Likes on 1,367 Posts
Of course you can use other brand batteries - but if you have LiFePO4's it's going to cost you a bundle and upwards of $1,200 bucks. Thus insurance by getting an $80 dollar CTEK charger/maintainer is a no brainer.
I don't think Varta sells batteries in the US (car batteries that is), the closest you can get are Interstate and what we used when test driving for VW/Audi/Bentley. I've got them on every vehicle I own: camper, bobcat, Touareg and Macan.
Last note, do NOT connect (if charging via battery) the negative cable to the battery. There's a dedicated ground post; use that.
siberian
Quick Reply: Lithium battery charging
