Matrix lights and US Govt approval
I have these lights on my 2021 Cayenne GTS. They work as described above exceptionally well, especially the "encounter" feature. When travelling on an undivided highway, you have leave the Matrix LED on high beam and they "look away" from the oncoming driver so you never have to switch to low beams. having said that, the car (911) drives just as well with the standard lights. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
But having had coded the adaptive headlights myself on my 2015 M4 and 2019 M4cs allowed me to really appreciate the feature, I was just quite pleased Porsche offered it from the factory in Canada.
Received 5,406 Likes
Regarding the matrix headlights, can current owners comment on the dynamic functionality? For example, I feel my 991 had more dynamic turning functionality than my current 992 GT3. They just don't seem to pivot as much in corners. Anybody have thoughts on this? Thank you.
Originally Posted by CodyBigdog
Wow, your already have your 992 GT3. Must be one of the first as Porsche web site says “sometime in the Fall 2021”, and I know m,y dealership said they won;’t have any until Spring 2022. Congrats. If I were to upgrade my 992S, it would be to the GT3, NOT the GTS. Again, congrats on having a very special Porsche.
Originally Posted by mferris
@LexVan you may have seen my other post but my (US/non-activated) matrix lights do no, or imperceptible, pivoting in corners.
mferris (11-06-2021)
I examined the Matrix headlight movement of a 2021 C4S in my scientific laboratory, the garage wall.
My calculations estimate a 5-7 degree low beam and high beam movement between full locks.
Nearly imperceptable.
Be aware I wore a bath robe rather than a lab coat.
mikey94025 (11-07-2021)
Received 2,866 Likes
Maybe they use the VW logic; our ‘14 Beetle has corner lights that are fixed but only light up when you turn the wheel. I’m only 1/2 joking; perhaps the idea with matrix lights - when working as designed - is that certain elements only light with lock applied?
