Disconnected exhaust tips on 2022 Z06
I just watched the 26 minute video on the new Corvette Z06, and they were talking about how they are able to achieve getting more exhaust sound into the cabin. One of the ways that they do this is to disconnect the tips form the exhaust. I am quite happy with the sound of the exhaust in the cabin of my 992C2S, and it has this disconnected exhaust tip thing going on, which was a head scratcher for me. I will say, the tips stay cleaner, but I never really understood the reason for the disconnect. Is it sound related??
The bumper design may have aero implications. Having a full length bumper cover means the exhaust needs to be surrounded by the bumper. If you have a true connected exhaust, then you need to have a healthy amount of free space around the tips to allow engine movement as well as heat dispersion to avoid warping/discoloring the bumper cover. This can be problematic aesthetically and possibly with aero.
The true exhaust tips on the 992 are also not particularly good looking or symmetric and attaching artificially symmetrical and wide tips is still a synthetic/aesthetic choice. So what's really the difference?
Then there is marketing. The sport exhaust and regular exhaust are mechanically identical. The difference is programming. Swapping bumper covers to identify the sports exhaust helps with selling the upgrade as being truly unique.
Everyone is doing this to reduce expensive damage in minor rear end collisions. You’re going to see more of it.
FUN FACT: It’s also Porsche heritage — the 959 had fake, disconnected exhaust tips. Nobody ever complained about that.
At least, on our cars, the exhaust comes out of the holes where it should. It’s not like the Audi Q5 that has fake exits at the rear when the exhaust actually faces down. Once you see it, you can’t unsee it.
I posted about this in the 991 forum, and it applies to the 992. It is my feeling that disconnected exhaust tips allow sound pressure to escape into the body of the vehicle. My opinion is based on rifle barrels. Sound and exhaust gasses escape a rifle barrel forward, but also at 90 degrees, of the direction of projectile travel. If the exhaust pipe terminates prior to the exhaust tip, and therefore still within the vehicle body lines, sound pressure will affect the body panels and end up inside the cabin.
With my 991 C2S, I chose to eliminate the OE gap between exhaust pipe and exhaust tip by connecting a separate tip to each pipe. In my perception, with the exhaust pipe now effectively terminating BEYOND the body line, the exhaust sound and boom of my aftermarket Soul exhaust was moved to behind my vehicle. I experienced no droning or resonance at nearly all RPM and certainly none at typical highway speeds and throttle. Note, I also eliminated my sound symposer prior to modifying the exhaust tips, and still feel the tips made a perceptible difference.
Received 2,906 Likes
All this talk about fake exhausts being to do with noise. Nope, it’s simply a cost thing. Cheaper to manufacture, cheaper to repair, and more freedom for designers. Some cars don’t even bother, look at a non-sport pack version of a W203 Mercedes from 2000 or so. No sign of an exhaust at all, I’m sure there are others.
Bluehighways (11-01-2021)
Received 2,719 Likes
aggie57 (11-01-2021)
