M-Engineering - ProTune with Pure Turbos Upgrade on 992 Base
#61
Do you know someone who actually upgraded a Base with Pure800 and how his/her experience is? Wonder how that power makes the "deficiencies" the Base has vs S and GTS more noticeable (no LSD, different suspension, smaller brakes etc). To me, that sounds like a very cost efficient upgrade to a Base. I assume you recommend upgraded intercoolers for that package, correct?
The following 2 users liked this post by mattchow:
DEALKLR911 (09-23-2022),
Tobeit (07-20-2022)
#62
#63
Platinum Sponsor
That was also on 91 octane CA gas which is awful as we all know. With proper 93 or even race gas or ethanol, these cars can boogie even more. Intercooling is always helpful especially with turbo upgrades.
-Charles@M
-Charles@M
#64
So, if I were to upgrade to Pure800 and your tune one day (maybe no intercooler as I don't race and just like the power on the street once in a while)...what would you think is the first OEM component of the base model to break from all that power and I would have to watch out for? On my AMG, once you got to > 700 the tranny did not like that et all and a tranny upgrade was almost mandatory.
#65
Platinum Sponsor
Haven't seen anything break on these cars yet, they are really stout. PDK2 tune will be needed for clutch clamping forces or they can slip as you make bigger power. But nothing breaks.
We manage torque down low so that there is not too much stress on the stock connecting rods. That is part of the tuning process.
Lol just budget for tires sooner.
-Charles@M
-Charles@M
#66
-Charles@M
-Charles@M
#67
Platinum Sponsor
Sounds almost too good to be true. I assume anybody who buys your standard tune first and then upgrades the turbo's later there is a tune upgrade fee or have to buy an entire new tune? Also, even after turbo upgrade there is really not anything different to the standard maintenance and service, i.e. I still can roll it to the dealer and have them do these in the suggested intervals. Maybe only thing would be that the tune needs to stay on the car with the turbo's installed, i.e. not like stage 1 tunes that you can flash back before service. Last general questions: if Porsche rolls out a mandatory ECU SW update, I assume we can pull a new baseline and get your tune updated to match the ID?
Service remains the same on the car, it's just a larger turbocharger installed.
If Porsche updates your ECU and changes the ROM ID, we can send over a new map for no cost. No need to retune it we just need to update it as a new file generally.
-Charles@M
#68
If you already have M-Tuner, you don't have to buy M-Tuner again. However, you will need a ProTune when you upgrade to bigger turbos and there is a cost associated with that along with any dyno rental you do.
-Charles@M
-Charles@M
#69
Platinum Sponsor
M-Tuner is the M-Engineering dongle plus our software. If you go to flash the car after a service and the ROM ID no longer matches, our software will not allow you to proceed forward. It will give you a notification about a mismatch.
At that point you would simply send us a fresh "read info" of your ROM ID and information and we'd make a new map. It's not too big of an ordeal to manage. Porsche has done this with the 996, 997, and 991 so we are familiar with this situation when it happens.
-Charles@M
-Charles@M
#70
How would a completely stock car with Pure 800 turbos act? Obviously not stock, but would "like stock" be accurate enough? I'm just thinking way forward after acquiring turbos, then subsequently taking the car back to stock minus the upgraded turbos since the cost to just buy new turbos is so cost prohibitive.
#71
Platinum Sponsor
If you are going back to stock with upgraded turbos on the car, it needs to have a matching calibration for it to run correctly. If you run the stock tune with upgraded turbos the boost mapping and lambda targets may get wonky and it'll not run right. It's always important to having a matching tune per the parts on the car if they require tuning, and turbos do.
-Charles@M
-Charles@M
#72
-Charles@M
-Charles@M
#73
Platinum Sponsor
Smog differs from state to state and county to county. We never designed our calibrations to circumvent or go around smog or emissions testing. The only way to guarantee passing is to have a totally stock vehicle.
Depending on where you are or what parts you have it may not be an issue.
-Charles@M
-Charles@M
#74
-Charles@M
-Charles@M
