Winter Tires?
Old 09-01-2021, 08:49 AM
ryandarr1979
ryandarr1979's Avatar
Can’t speak about the Conti Winter Contacts, but I have owned other Contis and been very impressed. I have Michelin Pilot Alpin 5s and they’re amazing in the snow, ice, etc. The limiting factor is the car and the ground clearance, but the PA5s make the car feel capable of any weather. I did just order a set of the new Conti Extreme Contact All Season DSW 06+ for my daily driver as they are rated number 1 on Tire Rack’s Ultra High Performance All-Season list, ahead of the new Michelin Pilot 4 All-seasons which are number 2 and more expensive.
Old 09-01-2021, 10:55 AM
Curvehound
Curvehound's Avatar
Originally Posted by TrackJunke
Yes. RAS works with 20 in rear
great, thanks
Old 09-03-2021, 12:13 AM
Jack F
Jack F's Avatar
I’m pleased with Michelin Alpins. You would be pleasantly surprised to see how when the car handles at speed at how well in corners on dry roads during winter.
Old 09-16-2023, 10:11 AM
Grimz
Grimz's Avatar
Anyone here has Michelin Pilot Alpin 5 on a GTS?
My dealer offered me those with the dimensions 305x30x21 for the rear but I thought that the winter tire dimensions were 295x30x21...
Cheers & Godspeed
Old 09-16-2023, 07:40 PM
dixonk
dixonk's Avatar
Received 1,733 Likes on 777 Posts
Cheers & Godspeed
Stock sizes for stock summer wheels and smaller sizes for the smaller optional winter wheels. I run the 305 winter on mine.
Old 09-17-2023, 04:23 AM
Grimz
Grimz's Avatar
Thanks mate - but I really thought that you need to run the smaller ones (295x30x21) for winter...
Old 09-17-2023, 10:23 AM
alin2
alin2's Avatar
The narrower 295s might be a bit better for snow/ice traction, but the stock summer size in 305 is readily available in Michelin and Goodyear N-spec winter rubber and fit the stock 21x11.5 wheels. The 295 would also fit of course.
Honestly either would be fine for cold weather/winter driving with the exception of severe snowy conditions where the 295 width might give a slight advantage over the 305. But, then again, the 295 isn't exactly a narrow tire either...
Grimz (09-17-2023)
Old 09-17-2023, 04:01 PM
Grimz
Grimz's Avatar
Fully agree on the grip level with the 295 option and good to know that I won't be the only one on the standard sizes
Old 07-30-2024, 07:56 PM
freesole
freesole's Avatar
This is probably a dumb question but I don’t know the answer. For winters it seems the 295 width works for the stock 11.5” rear. If my wheel is 12” on the rear, would the 295 still work ok?
Old 07-31-2024, 01:47 AM
CurryPuff
CurryPuff's Avatar
Whilst 295 may work with a 12" rear, depending on the manufacturer as the actual width may vary, the ideal for 12" is 305mm or 315mm.
Here's a table for reference.
The following 2 users liked this post by CurryPuff:
freesole (07-31-2024), OMTarga4S (07-31-2024)
Old 07-31-2024, 11:06 AM
freesole
freesole's Avatar
Ah this is super helpful, thank you. I haven't seen this table before.
Quick Reply: Winter Tires?
