360 degree dashcam recommendation
Looking to install a 360-degree dashcam that can record continuously while driving/parked (probably need to be connected to battery).
Any recommended camera that would fit in a 992?
Any dealer near NYC that could do the installation job at a good price?
My suggestion would be to use a Garmin mini camera and plug the USB into a small lithium battery, which incidentally could be used to jumpstart the car if the battery is dead. The lithium battery is charged whenever you run the car if it's plugged into a cigarette lighter.
Antigravity and other companies make such a product.
You can then use a suction cup running one or two cameras stuck to windows to record what's going on when your car is parked an a hinky area.
The upside of this method is no installation cost, relatively inexpensive, and you're not draining your cars battery. You also have the benefit of the backup lithium battery to run devices and jumpstart your car or anyone else's car.
The downside is the minor hassle of having to plug the camera into the battery before you leave your car, or if you choose to take the camera down every time to put it on the rear window or side window with a suction cup.
There are some great YouTube videos of Tesla owners actually catching people after images are submitted to police, who vandalized their cars out of spite using their 360° cameras.
I have two vehicles that have cigarette lighters front and back and run a dash cam as well as a camera pointed rearward to catch the license plate of people do rear end collision and then back up and take off the other direction, or make some wild fallacious claim such as you backed into them, or pulled in front of them suddenly and slammed on the brakes. Ask me how I know.
The following 2 users liked this post by Tompoodie:
BIGWORM (07-25-2021),
Juan.Valencia (07-25-2021)
I would prefer a solution that doesn't require any form of additional work every time I leave the car (as it wouldn't be worth the hassle otherwise).
What kind of battery should I be looking at? Which category on Antigravity? Would https://antigravitybatteries.com/pro...l-case/ag-401/ suffice?
Would a single Garmin Tandem (interior+exterior recording - https://buy.garmin.com/en-US/US/p/67...n/010-02259-00) suffice? Could that interior camera capture any side/rear collision and vandalism?
Would that be the same as having 2 cameras with one facing backwards?
Why do you have to plug the camera into the battery before you leave the car? Can't it stay plugged in permanently? Is it because the battery is huge and there would be nowhere to place it? (floor of rear seats perhaps?)
The backview cameras are nice. But they are big. They are a pain to install and a pain to get video off to you phone for easy sending.
Get the garmin minis!
riwu, You're correct, it could stay plugged in all the time.
For aesthetics I would only do it when I was parked in a place I was concerned about a break in or vandalism. I try to avoid those situations!
We are not allowed to post links, but simply go to the Antigravity site and you'll find it.
There is a button that needs to be pressed on the unit for power to be routed to the USB outlets. It's not on all the time. When the lithium battery is plugged into a cigarette lighter it charges automatically of course when the car is running.
And I agree with the above post that you would need more than one as each camera only points in one direction, although it is a fairly wide angle. Hope this helps.
Premium Sponsor
One of the main concerns you are looking at is when you have have several little cameras drawing on you main battery, and if you have additional electronics devices also, all pulling from your main battery it will create potentially a significant parasitic drain that can drain you battery much faster than you think.... perhaps even within a few days especially if the battery isn't new or in good shape and the car isn't driven enough to give its battery a solid full charge. You will find your battery drains and potentially won't start the car in just a few days of not driving.
So what you do want to review is how much energy those devices, though small, are pulling, and other accessories you plan on having. Also you need know the Milliamps of those Batteries batteries so you can find larger battery capable of recharging, or running those at night to them to keep them going when you are not driving. So though it appears a normal Car battery is big , they really can be drained or get low very quickly with a decent parasitic draw on them. Also flags start appearing when the Porsche's batteries get low so watch for that. Porsches are crazy finicky with low voltage scenarios. Last, You want to make sure you wire in the cameras so they do not effect the cars ability to go into sleep mode. Meaning attached to a fuse that might not allow the Car to fully shut down like it normally would. We have see that with people who installed some Electronics themselves. I am not saying this will happen absolutely since I don't have enough experience with these cameras and their draws, but I can safely say that 4 Cameras going at once can provide for a significant draw that may effect the cars ability to maintain a good high state of charge after a few days to a week of not driving, when normally most Porsches can sit roughly a month without needing a charge in general. So you may want to be keeping it on a charger more often after doing this also.
I am not well versed on this subject but if they offer bigger batteries for your cameras and they charge when you drive enough to run them overnight try to find that. I can offer some suggestions for stuff from our product lines, but often times these Cameras make solutions like this already that do work well and you would want to look into that first.
