PCCB or not to be
#31
All this talk about the superiority of PCCB performance. Outside of tracking and less brake fade in that setting, I don’t get it. In fact, stopping distances are no less and actually the opposite based on Car and Driver reviews of various 992s. As to brake feel, that is subjective - an issue for some, not for others.
Unsprung weight.
Actually three.
Reduced unsprung weight.
The following 3 users liked this post by ipse dixit:
#32
#33
Subjective? Sure. But so is a lot of what we like about these cars. PCCB vs Iron may or may not be faster on a track. I haven't done an A-B comparison and doubt that I'm good enough to exploit the advantages of PCCBs to prove the difference. On a street driven car, though, I'm not as concerned about lap times.
Porsche probably has some of the best EPS on the market, in terms of feel. Doesn't mean it necessarily makes the car faster. But it does make the car more enjoyable to drive. For me, it's the same deal with the brakes. Worth the money? When you add in the looks and the fact that you never have to clean them - it's a no brainer for me. YMMV.
The following 3 users liked this post by rk-d:
#34
For me, it's the feel. With PCCBs you can meter out incredible and immediate power, very precisely. The brakes allow this without being grabby or having a wooden feel or no modulation. The net result is that you can brake later in corners and there is no fade. It changes the way the car drives, as a whole. It elevates the entire package - the car feels like a higher performance machine.
#35
I've specced a base on the configurator with PCCB and it comes to roughly the same price as an S with standard brakes. Would you take the base PCCB car over the S with standard brakes? The answer doesn't directly apply to me, as I'm likely going with MT, but would help me think about how much you value the PCCB.
I will say this — if I was building a new C2S and was told to only pick one option on an otherwise bone stock car…it would be PCCB.
#36
Yes, that would be a legitimate technical advantage, but again my speculation is that it would only be noticed on the track. In addition, if it were a major difference, suspension modifications (spring rates, damping, etc) would be warranted to take advantage of such weight improvements. Yet, I believe Porsche does not change anything when PCCB is specified. On the street, I doubt anyone can tell the difference. Then again, there are some very sensitive butts around this forum...
#37
And, no, you need to adjust suspension settings when swapping out irons for carbon ceramic brakes.
#39
I dont think you will find many people say they regret getting the PCCB. Get them!
RacingBrake (06-29-2021)
#40
Nothing here about brake feel or unsprung weight. Bottom line, $9K to look cool and keep your wheels clean. So a very personal choice.
https://www.autoblog.com/2019/03/24/...r-race-tracks/
sexfiend (06-29-2021)
#41
SBAD (06-30-2021)
#42
Former Vendor
This CCM rotor kit is specially developed for 991 GT3/Turbo upgrading from Red calipers w/iron rotors to the latest CCM brake technology.
*If a CCM rotor is frequently running over the threshold temperature, the carbon will start oxidizing (losing carbon) resulting "pitted" surface which would act like a super grinder that can quickly wear out a new set of pad in just a few laps.
Avoid:
Learn more about the different generation on CCM rotors.
Contrary to common belief (per old ccb some 20 years' ago), based on our recent track tests on two Mustang GT350, the advantage of CCM for track racing is even more than street driving in performance and durability (replacements).
- 100% Bolt-On installation, easier to install than replacing stock iron rotors due to lighter weight.
- RB discs are made with Gen 4 CCM technology; with long (continuous) carbon fibers and angle vanes.
- RB CCM rotors are stronger and can run cooler than OE pccb.
- CCM rotors (Brembo, ST or RB) have "Diamond hard" surface with excellent "Thermal Stability" so they will NEVER Wear*, Warp, or Crack (due to the heat). More advantageous for tracking/racing.
- Rotor annulus are wide enough to fit Pccb pads (74mm vs. iron's 62mm in depth) for lower braking temperature.
- Runs on street or tracks w/o temperature (cold or hot weather), or water (rain or car wash) effect.
- Never rust, always looks like new.
- Literally no brake dust.
- Reduce unsprung weight.
- Improve driving comfort.
- Inspiring braking confidence on tracks.
- Substantial reduction on maintenance cost and downtime in pad and rotor replacements.
- Save money than iron brake in the long run.
Avoid:
- Running rotor continuously above threshold temp @650F
- Running brake pad below 1/3 of the lining material (~4mm)
#43
Has anybody tried ceramic brake pads on stock iron rotors? I've done this on my current car that dusts like crazy and the ceramic brake pads cuts down at least 95% of the brake dust. In fact, I can easily go weeks or months and the rims just don't get dirty. I doubt they are as spotless as cars w/ PCCBs, but for the costs, it probably gives 80-90% of the cleanliness of PCCBs. Braking performance is totally fine and just as good as stock pads, but I don't track my car or anything so I can't attest to how well they perform under extreme pressure.
Here are some ceramic pads I found for the 992. Just curious if anybody has tried these:
https://flat6motorsports.com/collect...ds-992-carrera
#44
If you drive it a lot getting a stone stuck on the PCCB's will cost you massive massive money. Not worth the headache if you have a budget.
#45
I opted for PCCB on my C2S and I definitely don't regret! The bite is incredible, even with low speed ranges such as coming up to a red light. The pedal feel is excellent, much more reliable feedback than coming from standard brakes. Expensive option but in terms of performance and up front cost savings (as opposed to an aftermarket conversion) it's one of the best options you could add. Clearly a personal choice, but I would rather spend the money on improving performance than on Burmeister or fancy leather bits.
smiles11 (06-29-2021)
