Targa sports suspension
I believe because of weight. Yes, the 991.1 and .2 Targas also didn’t offer SPASM either. The GTS got a 10mm lower ride height instead of the 20mm reduction of the coupe and cab.
i never knew this. I thought all SPASM lowering was 10mm across all platforms. I lowered our Targa with a HAS from Techart 20mm...and while I find I it perfect, I am surprised a manufacturer would sell a car at that height - particularly without FAL.
Wait somebody else just told me that the targa GTS on 991 didn't get any lower suspension.... I'm so confused about this. I've kind of been holding off to see the targa gts hoping that it gets slightly lower ride height vs t4s. (also allocations are 10k+MSRP minimum right now so I'm waiting it out anyways)
I am thinking about the targa also, but am interested in what GTS gets. But I find it hilarious that everybody considers the targa heavy. Yes its heavIER than the rest but at 3600 lbs its not THAT heavy. GT500 is 4k+, new M4 3800+, Mustangs 3900+. Its still medium lightweight vs other 2 door options. So I really think it would be fine if you dropped it on KW Height adjustable springs down to less ride height. If I do get the targa I wouldn't have an issue dropping spring in it. I also would not want PDCC, as I want actual anti-roll bars and less computer fidgetry. It's why I'd spec a manual and pccb dropping weight probably 100 lbs. If the GTS comes with center lock wheels though I'll have to pass, 400 ft lbs torque wrenches just do not sound fun and extra maintainence.
Go Bruins (04-29-2021)
It's where that weight lies, and the decrease of structural rigidity due to that additional weight.
The Targa's additional weight is higher up, thereby increasing the CoG. If you're looking at the G80 M4 or GT500, those cars are no doubt heavy, but their mass is generally down low (or below the belt line of the car). It's not high up on the car, like the Tartga, to account for the Targa's retractable roof.
To compound the added weight is the lack of structural rigidity because of the Targa roof.
It's not just heavIER, as you say.
With a higher center of gravity you would think that would make the argument for the option of lowering the suspension.
Honestly I don't understand why Porsche doesn't make a removable/stowable roof like the original targas. I don't even want that crazy complicated machinery. That solves the weight issue and saves considerable cost.
I guess in a case study people didn't want to get out of the car and wanted a button to press. Porsche I guess decided a push button solution made people happy.
I had a 2016 Boxster Spyder and never thought the somewhat finicky roof was an issue. Maybe I'm not the target demographic for a Targa (even though I'm waiting for an allocation) but I would have had no problem taking the top off myself and stowing it.
