Bedding-in brakes in new 992
My car will soon be delivered, and I was wondering how many people bedded in their brakes in the way that is often described in various websites-- multiple slow-downs from 60 to 20, no complete braking when rotors are hot, etc. I believe the owners manual is silent on a bedding-in ritual, other than to say that hard braking should be avoided for the first few hundred miles.
In my previous cars, I’ve done a few high speed stops and called it a day. Never put too much value into the bedding process. Now, if I was getting brake squeal, I’d do it just to help eliminate some noise.
Again, if you have racing brake pads, follow the process given in the manufactures instructions. Higher quality brake fluid is also vital in this situation.
Thanks. I'm not going to ever track the car or abuse the brakes. I was just wondering whether the bedding-in process, described so often on the web, is recommended for a new 992 to assure optimal performance. It sounds like it's not.
You don’t need to bed in the Porsche brakes.
You can, but not necessary.
The OEM pads are not aggressive enough to require bedding-in, and in fact are cured/bedded-in at the factory.
Received 4,134 Likes
Show of Hands:
1) Who here has ever had a brake failure or pre-mature replacement issues from failure to bed in the brakes?
2) Who here has ever had to replace or repair an engine due to wear from running over 4K RPM's when new?
<pindrop>
....didn't think so.
(My break in procedures for all my cars, trucks and motorcycles is pretty much 1) Look Left, 2) Look Right, 3) Nail it.
<pindrop>
The following 3 users liked this post by drcollie:
Received 2,842 Likes
Show of Hands:
<pindrop>
<pindrop>
Bedding gets more and more important as your pad compound gets more and more extreme. You have to burnish the brakes to get good braking performance on track pads. Conversely if you street drive your track pads with light braking applications you actually end up un-bedding because at low temperature, the pads are super abrasive and you are scraping pad material off the rotor, and you have to re-bed them at high temperatures to get pad material to transfer to the rotors again. In the case of stock pad material, they are beyond mellow and you don't have to worry about it.
eagle1960 (01-16-2024)
Show of Hands:
<pindrop>
<pindrop>
