How Would You Redesign the Gauge Array?
Old 03-01-2021 | 09:40 PM
Russian Mafia's Avatar
Russian Mafia
Default How Would You Redesign the Gauge Array?
They put the gauges in the car but we can't really see all of them. How would you change them?
Old 03-01-2021 | 09:53 PM
Bluehighways's Avatar
Bluehighways
Porsche is cramming the 5 gauge appearance into far less horizontal space than the original mechanical gauges occupied. The mechanical gauges forced the spacing by virtue of their design. The current “gauges” are video displays. Porsche is using two (one Left and one Right) medium sized displays to simulate two gauges each. If Porsche used two larger displays or four small displays this would cost more, but would eliminate the current shadowing of the outboard gauges.
Old 03-01-2021 | 10:33 PM
Russian Mafia
Would you be arranging the displays so they’d be visible inside the steering wheel?
Old 03-01-2021 | 10:38 PM
Bluehighways
Three inside and two outboard of the wheel rim. Spacing and a slight curvature of the panel would do it. The 997 solution doesn’t appeal to me.
Old 03-01-2021 | 11:00 PM
Russian Mafia
So as opposed to this from the 997, separated displays?
997 Display
Old 03-01-2021 | 11:02 PM
Noah Fect's Avatar
Noah Fect
A HUD. Porsche should keep the nice big tachometer in the center for old time's sake, and put the rest on the windshield.
Frankly it's ridiculous that cars still have gauges at all, and yes, that goes for you too, Elon.
Schwarz992C4S (05-20-2023)
Old 03-01-2021 | 11:04 PM
Russian Mafia
For reference, here's the 992:
992
Old 03-01-2021 | 11:05 PM
aggie57's Avatar
aggie57
I’d prefer the 997 setup.
Old 03-01-2021 | 11:17 PM
Bluehighways
Something more like this kind of spacing where the steering wheel cuts through the space between the two outboard gauges and the gauges that flank the tachometer.
If you compare this to the picture of the 992 above, what stands out is the spread of this early dash reaches from side window to the center of the car (note the gearshift lever position) whereas our 992's end at the edge of a rather wide console.
Old 03-01-2021 | 11:32 PM
siberian's Avatar
siberian
I'd rather have the analog gauges as in the 997 or 356. And yes the steering wheel is in the way of two of the gauges. While we are at it, I would revert back to console switches rather than having to aim your finger at something on the 11 inch screen and PLEASE get rid of the domino. It might be great at an art exhibition in Berlin but it's silly in the car; yes of course IMHO goes without saying
siberian
Old 03-02-2021 | 12:01 AM
Bluehighways
What I find interesting; Nowhere in the Owners Manual or on Porsche's web site do you ever see a drivers perspective of the dashboard with anything other than blank space where the gauges would be. The only view like this is in the pictures provided in the configuration tool (see below).
Old 03-02-2021 | 12:09 AM
Kats's Avatar
Kats
The obvious answer would be to arrange the gauges digitally in the same way as they were in prior analog generations. Why the need for full circle speedometers etc?
Old 03-02-2021 | 12:14 AM
Cheshi143's Avatar
Cheshi143
2 of the 5 analog gauges were worthless as far as a modern car is concerned. There is no need for a quartz VDO clock and you can only see half of the left sided gauge because the steering wheel blocked it. The way it currently is, not too bad except you cannot see the fuel gauge for ****. On my 991.2 at least the fuel gauge appeared in some of the MFA screens so you could see it there.
G650 (03-02-2021)
Old 03-02-2021 | 12:33 AM
rk-d's Avatar
rk-d
That works well with the old thin rim, large diameter steering wheels. In my '98, the 5 gauge spread cluster still works, but visibility does suffer a bit. Of course the 992 is much worse than this. Personally, I think modern steering wheels are way too thick.
Old 03-02-2021 | 12:45 AM
ipse dixit's Avatar
ipse dixit
We are still talking about this?
Slow day on Rennlist.
Quick Reply: How Would You Redesign the Gauge Array?
