Interior rear side panel removal
Old Jan 15, 2021 | 02:07 AM
PCJR's Avatar
PCJR
Default Interior rear side panel removal
Can anyone help with how to remove the rear side panels, the ones just behind the door which hold the rear speakers. I'd prefer not to start yanking on them so if anybody has experience or manual I'd appreciate the guidance.
Old Jan 15, 2021 | 03:22 PM
Norge911's Avatar
Norge911
Why are you removing them?
if rattle, try and access through speaker. Speaker cover is secured by six tabs and a thin interior tool is your friend. Then remove speaker, T15 6-point.
the little tweeter may rattle with Bose. Remove, wrap w electrical tape and reinstall.
if not tweeter, just get some sticky felt material and see if you can’t fix when speaker is out.
it for other reasons you need to remove panel, see post 92 here. From 991 but most likely similar. Not an easy panel to remove.
https://rennlist.com/forums/991/1173...project-7.html
Old Jan 16, 2021 | 01:53 AM
PCJR's Avatar
PCJR
thank you for your reply. I have a bit of an intermittent buzz that the dealer cant seem to resolve. I thought if it was an easy task I'd have a go at it myself. It does seem to be coming from the speaker area so I may just take a run at that. If not I will take it to another dealership.
