I have a Yellow 992 with full PPF. I would like to vinyl wrap the hood black - Just the hood, I have a black glass roof, so a glossy black wrap would match. Not a permanent change, just as a bit of a change.
So, knowing that any rock chip will show yellow through, and knowing any exposed edge will show, will the PPF stay on when I go to remove the wrap, or will I have to re PPF the hood afterwards.
Several internet sources say both yes and no, including one YouTube video where they did it.
Does anyone have an experience? Can I just go to a car wrap dealer and ask them to do it, and how hard would it be to DIY this kind of thing. One panel, but pretty contoured.
Ideas?
Honestly i don't know anything about PPF/Vinyl interaction but the folks who did our PPF recently released a video about vinyl that touches a bit on vinyl/PPF: https://www.esotericdetail.com/custo...-superleggera/
They are a forum vendor here, perhaps they could shed some light on the topic. I know they've also done some graphics work on a friends 991.1 GT3 that i believe was PPF'd with graphics over the PPF.
Ideas?
XPEL makes a black PPF for this type of application — looks great.
Regardless of what product you use, I would remove the current PPF before putting any other product on top of it. You’re going to get better adhesion. Plus, if you pull it up after putting it over PPF, the PPF underneath would be much worse for wear.
As for DIY, I am totally comfortable with stripes and logos, but I leave large areas and curves to the pros. Having the hood redone professionally isn’t going to be a lot of coin.
You are correct- we worked on this project with Esoteric and the layering was PPF with graphics on top. This is usually the recommended course as it allows you to still be able to customize the car but easily be able to return it to resale condition when you tire of the look or sell the car.
You can absolutely wrap entirely over PPF. When removing, as long as caution is take around the edges, the adhesive on the PPF is usually stronger than the vinyl wrap so it shouldn't be affected. You may have some adhesive residue you need to remove, but generally it should be okay.
If you are wrapping the hood satin or matte, vinyl would be the cheapest easiest way to do it. If you are going gloss black, the current offerings of gloss black vinyl aren't very good for large surfaces as they have a lot of orange peel and haze, so as mentioned above a "black PPF" by STEK or XPEL is a great option to achieve the look.
Well done, an exquisite design. The small things like the rings on the center cap matching the calipers and blue striping can really knock things up to the next level. Beautiful!
I have done exactly that on my previous track car (vinyl over ppf). 6 years, no issues. Also the new black PPF is phenomenal. Check it out on my roof and the sides of the wing. It looks like paint.
