Wonder if this is happening on anyone else’s PCM system...
Most of the time when I turn my car (MY2020 CS) on after longer off periods or during cold start, my custom PCM tiles on the home screen take a while to load. They just show spinning loading circles for at least 15 seconds I’d say, and it’s not the biggest deal, but it can get annoying. It’s not even just the tiles associated with my Bluetooth iphone like my music playlist (btw I’m not using CarPlay), but it’s also on the car’s own system tiles such as homelink and sports exhaust toggle and Navigation. Example pic below.
I thought my car might need a software update, but when I took it to the dealer for some other service, they said there are no available updates for mines.
I had a previous Canadian/euro spec 992 for a couple of weeks and it never had this problem. I don’t know which PCM version it was on.
Also on a side note, the euro 992 had a dedicated main left-window-pane button for “Devices”, made it easier to toggle CarPlay on/off. This car however does not have that menu.. ?
My US spec car is on this:
And these are the annoying loading circles:
Any thoughts on this? And thanks for the help!
My PCM takes between 20-30 seconds to fully ‘load’ all the connections in my car, particularly if you use CarPlay, which is the second last connection to load for me. I’ve been told this is ‘normal’. Home link is always the last thing that loads and there are numerous threads about how people are not happy with it (time to load, reliability, etc). Just make sure you leave an extra 30 seconds every time you leave the house to make sure you can close your garage door with Homelink. :-) Some have resorted back to using a regular garage door remote or a third-party app so it can be done immediately. Fortunately, my Homelink is 100% reliable, just slow to load. I have set my diamond button on my steering wheel for Homelink for when I’m leaving the house.
On the far left you should be able to scroll down among those icons under the home icon and you should see the devices icon, no?.
I timed it this time and yea it’s a full 40secs for some of the tiles.
I definitely don’t have that “Devices” menu icon on mines, weird. Maybe because my car has a dedicated “Assist” menu icon button and all of it’s toggles.
I also have Homelink assigned to one of the diamond toggles on the dash.
Thanks for the info!
My January 2020 build takes 30 to 40 seconds on cold start. One trick to make it quicker is (even if unlocked), initiate the fob with an unlock before getting in the car, it will cut 10 seconds or so off the time. But it still takes 20-30 seconds to fully operational on all tiles.
As others say this is ‘normal’. I use the key to unlock the car from inside my house before I go to the garage, that unlock initiates the PCM load. Maybe the lack of a device tab is a MY21 thing? My MY20 car has it, I’m struggling to understand how you’d manage the phone connections without it.
It takes forever. It's absolutely infuriating. It makes Homelink less practical and the switchover from a phone call to the car takes ridiculously long.
My first euro spec car was also 2020, and it had the Device tab, but didn’t have any extra assistance systems except LKA, but my current US spec does have all the extra assistance options and thus has that dedicated “Assist” tab instead, so maybe that’s why?
But regardless, I can get to the Devices menu by touching the phone/data icon up on the top of the main Home Screen.
Originally Posted by reddsektor
And also, as I said originally, it’s weird how the euro spec car never did this loading thing! It just loaded right away every time. Mind boggling lol
Interesting. My car is US MY20 and has both the Assist and the Device tab. I have LCA and Surround.
OP-
Is the approach sensor turned on (settings)? When you reach for the screen, does anything appear before you touch it?
The boot time is like that for all cars with PCM 5. Perhaps you've been opening the car with the key fob beforehand, which starts the boot process. Actually that's what I do. Just when I'm about to go to the car, I open by key fob. Then it's all booted (most of the time) by the time I get in.
OP-
I gotta remember that because the 40-sec load time drives me bonkers :-)
OP-
yes the approach setting is on.
Yea I definitely will just start using the key fob, thanks for the tip!
Originally Posted by eagle1960
As I walk through the house on the way to the garage I push the unlock button and it's ready to go every time.
This. When you grab the fob to get ready to go, unlock the car. When I do this, I rarely have to wait to use Homelink to shut the garage door. (Fortunately for me, I have to pass the garage door button on my way out to my car, so opening the garage is before I get to the car. YMMV.)
