ECU tuning
Old Dec 27, 2020 | 05:33 PM
  #46
Mb111's Avatar
Mb111
Has anybody used or tried Softronic? I've been doing some research and they seem to have a good reputation from some of the other users on RL.
On their website it states that you do not have to send Softronic the ECU, it's done via OBD, and that you can go back to the stock software if you need/want. My question is does the dealer have a way of seeing you've tuned when you go back to the stock settings after you tuned. I don't know if my dealer is tune friendly and I certainly wouldn't want to void my warranty on a brand new car, but the extra oomph is enticing.
Old Dec 27, 2020 | 05:35 PM
  #47
Cheshi143's Avatar
Cheshi143
You are changing the software on the DME, it can be detected, it can void your warranty. So can a piggyback too.
Old Dec 27, 2020 | 05:41 PM
  #48
Mb111's Avatar
Mb111
OK - Softronic claims that when they tune, they make a copy of your original stock DME and they send you back your original file so that when you -'un-tune' or go back to the original settings it's the exact same software you had on there originally. Is that possible, or no matter what, even if you put it back to the exact original file, it can still be detected?
Old Dec 27, 2020 | 06:25 PM
  #49
NVRANUF's Avatar
NVRANUF
Yes but only if it's the piggyback system gets left on the car and is discovered during service. Easy enough to remove the physical evidence before, leaving no trace.
On ECU flashes, the ECU records the number of changes, regardless whether it's back to stock or left modified. If there's any questions and they check that ECU parameter it may then affect warranty.
Old Dec 27, 2020 | 06:31 PM
  #50
peterdouglas's Avatar
peterdouglas
so - if I understand correctly, a “piggyback” tune will be permanently detectable - even after physical removal and return to stock tune - and therefore may invalidate related warranty.
Is that correct?
Old Dec 27, 2020 | 06:36 PM
  #51
Mb111's Avatar
Mb111
Talking
Thank you for the answer, which was the best explanation I've seen on RL about the detectability of ECU flashes / tunes, and I've searched for it!
I assume when you take it in for routine service they aren't likely to check that 'parameter' unless there's an issue but anything's possible. If a dealer updates any of the other systems, PCM, etc, would that be recorded as an ECU flash or is the ECU flashing strictly limited to the engine (I think I know the answer, but just making sure)? As in, would a software flash on any system in the car obfuscate the number of flashes? Not that I'm trying to figure out any loopholes.... ;-)
Old Dec 27, 2020 | 06:45 PM
  #52
NVRANUF's Avatar
NVRANUF
Is that correct?
No not quite.
Piggyback tuning does not work like a flash tune which changes the ECU when flashed.
The piggyback system tricks the ECU into thinking "outside stock parameters" and increasing performance while it is plugged into the ODB port and would be only detectable IF you physically leave it in the car and took the car for service.
Old Dec 27, 2020 | 07:21 PM
  #53
LSM111's Avatar
LSM111
Racechip.us some decent gains and can be easily removed. It’s a piggy
Old Dec 27, 2020 | 08:06 PM
  #54
Michigan 992's Avatar
Michigan 992
Piggybacks are detectable by the manufacturers if they choose to look. Anytime peak torque or acceleration rates are exceeded the software logs it. For many brands the dealers do not have the ability to see these parameters with normal scan tools. It all depends on how the manufacturer feels about tunes and rejecting warranty claims.
Old Dec 27, 2020 | 10:20 PM
  #55
Tupper's Avatar
Tupper
Originally Posted by John Mclane
True car guy, very smart and hard working:
Alex Roy
info@petuned.com
PE Tuned
224.676.0756
Holy crap! That’s about 20 minutes from my house
Old Dec 27, 2020 | 10:24 PM
  #56
John Mclane's Avatar
John Mclane
I have to drive nearly 90 min. The drive back is a whole lot of fun...
Old Dec 27, 2020 | 10:29 PM
  #57
Tupper's Avatar
Tupper
How do feel about the tune you received?
Is the power gain as described? Is it equal across board? Have you encountered any drawbacks or issues?
Old Dec 27, 2020 | 10:35 PM
  #58
peterdouglas
so ... how about Porsche?
Old Dec 27, 2020 | 10:44 PM
  #59
John Mclane
Drawback is that you need to upgrade the brakes for track use if you want to fully utilize the power. With SPASM the suspension can wait for a V3 box. Fuel consumption increases as expected, not that I'm paying that much attention.
Old Dec 27, 2020 | 10:48 PM
  #60
ryanlsmith's Avatar
ryanlsmith
Alex Roy
info@petuned.com
PE Tuned
224.676.0756
Wow...so he already has a hand-held available?
