DIY Oil change
Old 12-01-2020, 10:26 AM
lucycan
lucycan's Avatar
Is it really much different than the 991 process?
Old 12-01-2020, 11:02 AM
eagle1960
eagle1960's Avatar
No. I honestly don't know why a DIY would be needed. The fan cover is much easier to deal with on the 992.
1. Remove oil and coolant caps.
2. Lift up and remove fan cover.
3. Remove right side fan.
4. Remove oil filter and replace cartridge.
5. Remove drain plug.
6. Watch oil drain.
7. Replace new drain plug.
8. Refill with oil.
The following 6 users liked this post by eagle1960:
aggie57 (12-01-2020), BOPE (04-23-2021), mdrobc1213 (01-09-2021), PBM (12-02-2020), Schwarz992C4S (03-05-2021), smiles11 (12-01-2020) and 1 others liked this post. (Show less...)
Old 12-01-2020, 11:28 AM
Quadcammer
Quadcammer's Avatar
Received 1,441 Likes on 834 Posts
Originally Posted by Mercuriell
dry sump
not really
Old 01-08-2021, 10:51 PM
siberian
siberian's Avatar
Received 2,356 Likes on 1,397 Posts
Get a Fumoto oil drain plug and never deal with crush washers, plugs etc.
siberian
Old 01-09-2021, 02:47 PM
lucycan
lucycan's Avatar
Is the process any different for the TT ?
Old 01-09-2021, 03:13 PM
kpblade
kpblade's Avatar
How difficult is it to get to the drain pan plug. Do you need to raise one or both rear wheels, or can you get to it without raising anything?
Old 01-09-2021, 03:15 PM
ryanlsmith
ryanlsmith's Avatar
Originally Posted by SamD
Only the right fan has to be removed to access the filter. Did this @ 3500 miles +/- and I have to say the oil going out looked very much like the Mobil 1 put back in . . .
How did you reset the reminder? Or did you not? The mechanical part of this process seems easy enough, but I haven't found a service tool that supports the 992...
Old 01-09-2021, 04:21 PM
user 64927802
user 64927802's Avatar
Originally Posted by Motorin Mark
Is that really a $2.00 plastic drain plug holding all of our oil in? or is it steel or aluminum with a crush washer?
yep
Old 01-09-2021, 04:23 PM
Bluehighways
Bluehighways's Avatar
Received 2,719 Likes on 1,280 Posts
You can reach it OK, but you'll never get your hand, a drain plug tool (or screwdriver) and an oil pan of sufficient size to catch 8 quarts of oil in there at the same time. Either a set of drive-on ramps or a floor jack and a couple of (good quality) jack stands are pretty much a necessity. I use the later, but if I were to use a set of ramps I'd probably want some that would raise the wheels about 5" off the pavement. You might be able to get away with the 3" ones, but even if you can it'd probably still be kind of a tight fit. Others may have real world experience in this area as to which ramps work the best.
Old 01-09-2021, 04:27 PM
Bluehighways
Oh yea, and for $10.50 (Amazon) you get 5 with the Tool! Such a deal!
Old 01-09-2021, 11:19 PM
mdrobc1213
mdrobc1213's Avatar
Good to know. Will add to my wish list/cart!
Old 01-10-2021, 10:23 AM
patentguy
patentguy's Avatar
I have jack, jack stands and ramps. Of course, it is difficult to use the jack points to jack and then put jack stands in the same place unless you have those special stands. On the other hand, on my 997 the ramps are so steep that the bottom of the car hits the stand before the wheels (anyway, I am afraid to miss ramps backing up when I am alone). So, my solution is to jack up each side of the car and then slide the ramps under the wheels. Very easy and safe..
Old 01-10-2021, 10:35 AM
WCE
User
WCE's Avatar
The dealer will gladly reset the reminder for a nominal $400 charge (and throw in the oil change for free)! 😁
Old 01-10-2021, 10:37 AM
RD16RR
RD16RR's Avatar
For those that are cost conscious....the first oil change is free (10,000miles)
Old 01-10-2021, 12:36 PM
siberian
siberian's Avatar
Put two 2x4s in front of the ramps.
siberian
Quick Reply: DIY Oil change
