Tidal Music App...
Old 10-05-2020, 06:40 AM
  #31
deetz307
deetz307's Avatar
I have the Burmester and it does not have TIDAL built-in afaik - like you i am on Android, and have the same disappointment with the lack of native Android Auto integration in the PCM (which is total BS for a 2020 model given other VW group vehicles have android auto support and Porsche even went as far as to build a aftermarket retrofit with Android Auto for older models).
Old 04-26-2021, 02:44 AM
  #32
Swift Shawen
2nd Gear
Swift Shawen's Avatar
Do you mean to listen to Tidal in your car? If your car system doesn't have an inbuilt Tidal app, you can directly use Bluetooth or CarPlay to do the same. Alternatively, you can try to play Tidal in the car using a USB. With USB, you should first download music from Tidal to local files and then transfer downloaded Tidal files to USB for playback in the car offline.
Old 04-26-2021, 02:57 AM
  #33
Joan Alcover
Joan Alcover's Avatar
Burmester does not have Tidal "built in".
Through Apple CarPlay you can listen to Spotify, Tidal and Qobuz; also Amazon Music, Apple Music and Berlin Philarmonic.
With Apple CarPlay switched on (in place ot the PCM), the quality of Qobuz (I have a subscription in Hi-Res) is very good.
Qobuz allows you to download musical files (your favourites) to you iPhone in Hi-Res if you have the Hi-Res subscription to Qobuz. Then you no longer need a live Internet connection when you want to listen to the music
Old 04-26-2021, 08:34 PM
  #34
FrankAT
FrankAT's Avatar
I use Tidal with Burm over CarPlay and don’t feel like the quality is better when plugged in vs OTA. In fact, I notice no discernible improvement in quality compared to lossy Apple Music. I wonder if CarPlay compresses by default.
Old 04-26-2021, 10:43 PM
  #35
xmlguy
xmlguy's Avatar
There is some encoding loss going via Bluetooth or USB, but you really won't notice much difference unless you have good speakers. I think Tidal sounds better than Spotify on my Burmester system, but I'm fairly sure its just positivity bias (it sounds better because I want to believe it does)
Originally Posted by findtom
I use Tidal. It’s not built into the PCM, as far as I know its only via the phone.
Yes, I found the same thing – PCM is limited to Amazon Music and Apple Music – I couldn't find a way to light up Tidal or Spotify, or anything else for that matter.
Old 04-27-2021, 04:12 AM
  #36
Patriot
Patriot's Avatar
Tidal no-go for me with its current ownership.
Old 04-27-2021, 08:46 AM
  #37
dgtarga
dgtarga's Avatar
Originally Posted by Vintage72
What other alternatives to TIDAL are available that provide "hifi" tracks?
Amazon Music HD. And is supported through Apple Car Play.
Old 04-27-2021, 09:05 AM
  #38
Joan Alcover
QOBUZ, supported through Apple Car Play.
Quick Reply: Tidal Music App...
