Disable brake assist - persistence
So, I really don't want the brake assist enabled. I'm not here to argue the merits of having it on or off, and yes, it's possible I'm a horribly irresponsible human being for wanting it disabled, but I wants what I wants.
So I go into "assists" and turn that feature off. I turn off lane keep assist, and the brake assist features. The next time I get in the car, I see that the lane keep assist remains disabled, but the brake assist has automatically turned itself back on.
1: Is this normal?
2. Is there a way I can keep the brake-assist turned off without manually switching it off every time I start the car?
1: Is this normal?
1: Is this normal?
1: Is this normal?
The following 2 users liked this post by mikey94025:
G650 (09-15-2020),
Keith Morgan (09-15-2020)
Apparently this is normal and you cannot keep it off. According to the manual (page 171), Porsche Active Safe turns itself back on automatically: Porsche Active Safe (PAS - warning and brake assist) ... is activated automatically when the ignition is switched on.
You can turn it off on the assist menu. I drove my car in the track with no issues, it wouldn't be possible or allowed if the PAS stayed on.
I have a driver profile for track use, where all the assistance and other distractions are turned off. It kept it off even when cycling the ignition.
Seems like there's some inconsistent behavior.
Heads up for the first hard braking. The seat belt will pull hard and stay like that until you unclick it. Scared me on the first bend...
Gopro = ON
AC = OFF
Wing = UP
Mode = SPORT+
Display = Tire Pressures
LapTimer = Started
And now I'll get to add:
Brake/Lane Assist = OFF
Oh! Also, LOL at the seatbelt pre-tensioner. Mine did that at the Glen. The pressure was REALLY tight. I laughed, knowing what it was. The car thought I was involved in a 17 minute long crash.
The PCA groups I'll be running with will be fine with it, just as long as I disable it before heading out onto the pit lane. I keep a little paper checklist in my console for things like that.
Gopro = ON
AC = OFF
Wing = UP
Mode = SPORT+
LapTimer = Started
Gopro = ON
AC = OFF
Wing = UP
Mode = SPORT+
LapTimer = Started
You should be able to create a driver profile that remembers at least part of those settings. Sport/wing it wont, but the rest it should
Deleted. wrong post
