View Poll Results: What Paint Protection Option Did/Will You Go With
Traditional Wax Only
18
8.29%
Ceramic Only
18
8.29%
Partial PPF
33
15.21%
Full PPF
28
12.90%
Partial PPF + Ceramic
64
29.49%
Full PPF + Ceramic
36
16.59%
Nothing
20
9.22%
Voters: 217. You may not vote on this poll
Paint Protection Poll
#31
I'm an XPEL customer and I've done full wraps. The comment earlier about the installer is 100% right. Watch them wrap someone else's car before they do yours -- see how many panels, pieces, and components they take off to wrap, do they wrap the edges, do they just use a precut kit, etc.. Figure out if the PPF includes a paint correction or if you have to take it to them corrected since that's quite a big difference.
The one downside to PPF is that you run the risk of peeling paint when you replace or remove it all together. That one downside I can live with because it is reduced if put on correctly. It makes me not worry about swirls, bird poop, rocks, parking lot accidents, etc. and I can actually enjoy the car.
”It is highly unlikely for paint protection film to harm OEM paint. Paint systems used on modern assembly lines today produce a minimum bond strength of 16 MPa and maximum of 25 MPa between the panel and the paint depending on color, iridescence and the system used. Our film’s bond to the painted surface at normal state (immediately following installation) is .0753 MPa. Even after years of heat and sun, the bond between the film and the paint increases to only 0.17 MPa. What that means is in the absolute worst case scenario, the bond of factory paint to the panel is over 94 times stronger than the bond of our film to the paint. In the best case, the paint is 332 times stronger.”
im guessing other film manufacturers will also have similar properties so shouldn’t be an issue. Maybe it depends on the type of adhesive used?
XPEL (06-22-2020)
#32
Looks like I went with the most popular choice myself...
my question to some of you with the Ceramic is.. two fold..
1. Did you guys do the leather interior as well?
2. Are you applying any kind of "up keep" protection on your ceramic every so often? I know the stuff I use as a product called "Reload" that is a mist on / wipe off..?
#33
#34
As much as I think the ceramic coatings (CQuartz, Modesta, etc) are sort of voodoo magic, the self-replenish stuff like Reload is even moreso.
XPEL (06-22-2020)
#36
from Xpel’s website...
#37
You’re never going to get accurate result to this question here, the sample is just too skewed. Personally I can’t see the value in either, modern paints are just so easy to maintain. Regular washing with water and waxing was all I ever did on my last 911, it looked just as good after 5 years and 30,000 miles as it did when new.
As for protection, I’m in the patina camp. They’re cars, unless you have a museum they’re designed to be used.
#38
I expected the results to tip towards PPF just not by this far. But it could be like color polls where black (combining both metallic and non-metallic) comes in a distant third or fourth when Porsche says it is the number one color in the U.S. and Europe for 911’s. So yes this group is probably not representative of the overall group of Porsche 911 owners but they are probably more informed because of their passion for the car.
As for me, one of the reasons I switched to GT Silver at the last minute was because lighter colors hide road rash much better than darker colors. So I figured it would leave the door open to not doing PPF since if it gets a lot of chips not being as visible as it would be on black or Gentian Blue (other two colors I was contemplating) would be a benefit.
#39
I am in the ppf camp. It’s because they are cars and built to be used & enjoyed that I support it. For me, it’s all about preserving the paint. I don’t care if the film gets beat up, doesn’t look perfect, has edges or seams etc.... The film is there to protect the paint so the car can be driven and not sustain as much paint damage, not to make the car look better. On other cars , I’d probably just ppf the bumper and hood. For the 911, it’s really amazing how badly the rear hips get pelted. You either accept damage within a couple hundred miles in this area, protect it, or don’t drive.
As for the unfortunate experience of smiles11, that really sucks, but it shouldn’t happen with a good installer.
with modern paint and modern film, the paint should definitely not lift on removal of the film
gcurnew (06-21-2020)
#41
Properly installed PPF and properly removed PPF will not pull paint from the car. I've had Xpel removed and applied 3 times on my car with no issues.
Like we have always said about PPF, installer, installer, installer......
#42
Unrelated to Ppf, but related to rock damage. I just gave my car a wash and noticed for the first time that the matte black plastic side skirts are getting sand blasted directly in front of the rear tires. I suspect this is normal.
#43
yep.. mine too.. I assume they did that treatment knowing this is normal... Goes with the territory I guess,
rhr992c4s (06-21-2020)
#44
I have a stupid question: does having full PPF mean that we can now take the vehicle through automated car washes without having to worry about swirl marks? If so that would be really nice and a huge advantage in terms of convenience.
#45
I still wouldn't do it. I don't want an abrasive brush possibly catching any edges of my PPF, and with "laser wash" (touchless) being pretty commonplace, why you would use something that abrasive on a car you paid that much for is beyond me.
