Long warm-up time
The following 3 users liked this post by russbert:
paddlefoot64 (05-26-2020)
Yangpei, we are experiencing the same issue as you with 3 month old 992...very long warm up before it kicks down. I'm also concerned that if I make two or three stops throughout the day, maybe 1/2 hour or 45 minutes out of the car - it again ramps up after start up as if its the first start of the day. This happened yesterday even with mild temps in the 50's. My 19 Cayenne warms up in much less time and rarely idles up during the day once I've reached operating temps. I'll check in with the service department in the next couple of days.
please let us know if they find anything
Modern car should not idle until warm. The extra fuel used in order to warm up the cats washes out the cylinders
as others said, start and drive. For fast warm up, leave in Normal mode and drive in 2nd gear at 2500 rpm while leaving your neighborhood
smiles11 (02-05-2021)
I've had my 992 for about a month and haven't driven it a lot yet (about 70 miles total). But, I noticed that it seems to take significantly longer to warm up than my other cars (both current and past). After starting, the 992 often takes 1 1/2 - 2 minutes before the idle speed drops down to 750-800 rpm (even at fairly warm ambient temps around 80 degrees F). It seems like I'm sitting longer than I recall in other cars before being able to drive. It may be just because the car is new and not broken in yet. Just wondering.
+1. Better for the environment, better for the engine, better gas mileage, faster warmup (means entering the fun zone quicker).
