Noise Insulated Glass
#46
My lock date is 10/16 and this is the only option I'm still thinking on.
Has anyone received the 2021 with this option yet? Everyone was talking about how they are on hold pending emissions certs on the other threads though.
It seems everyone on this thread is looking for that person with the option to pitch in.
#47
Sure i have, but without a direct one on one comparison it's difficult to exactly measure.
#48
I was on the fence as well as I couldn't find a good description of the product and I had concerns about possible radar detector problems.
A little research shows that noise insulated glass has been around a few years and has been introduced in several cars. Apparently, it uses a special acoustic vinyl layer sandwiched between the glass which also allows the glass to be lightweight since the glass doesn't have to be so thick.
This is different from a Solar Coated windshield which has a UV reflecting film - and has been known to affect radar detectors and toll transponders even in non-Porsche vehicles. I believe this may be what was on those cars whose users had problems with this. Theirs were specifically described as such (helps with heat) and Porsche had instructions on where to put transponders.
Noise insulated glass mainly decreases noise from outside the car and is especially good with things like wind noise. They say it's useful for noise in the 1,500 to 5,000 Hz range and they quote a decibel reduction of 2-3 dB which apparently sounds small but helps with conversations in the car.
I honestly don't know what these numbers would mean in a 992 but I had initial concerns about how it might affect the engine sound before I realized the we do have a symposer that pretty much pipes the sound into the cabin. My 997 doesn't have this.
The way I see it, this might improve the level of unwanted noise inside the cabin which will be good for long drives, will not likely diminish the engine growl we all love, not likely to affect radar detectors and toll transponders, give us 8 lbs of weight savings and likely will improve the way the Burmester will sound in the cabin.
I went ahead and added this to my configuration before my dealer's freeze date.
You may want to also take a look at the current windshields in your other cars. You might be surprised to find that they too are noise insulated. I found that my Range Rover and BMW were - and those are very quiet in the cabin, though I am sure the glass is only one part of the sound proofing.
Since we don't have reports from actual owners yet, I thought these will have to do to make decisions.
You can google "acoustic windshield" and see what you come up with.
Some links I found:
https://bettersoundproofing.com/how-...ic-windshield/
https://soundproofguide.com/what-is-...ic-windshield/
https://lowbudgetautoglass.com/faq/t...r-windshields/
(Last link has pictures of the markings on the glass so you can tell if your car has it. )
Hope this helps.
The following 3 users liked this post by Black Stig:
#49
#50
Johnboston (10-05-2020)
#51
Received 2,647 Likes
That's actually quite significant. The dB scale is logarithmic. For example, a 20 dB sound is 10 times louder than a 10 dB sound. If it were a linear scale (it's not), 20 db would only be twice as loud as a 10 dB sound.
#52
Received 2,842 Likes
https://rennlist.com/forums/992/1166...-symposer.html
You'll get that regardless of the glass.
#53
I now also see that a 3 dB decrease amounts to a halving of sound levels. That’s definitely a significant decrease of external sound.
Bluehighways (10-05-2020)
#54
Now I'm curious as to what kind of sound reductions folks are getting on identical cars w/ and w/out the noise insulated glass. This thread has me curious. The only real loud part of the drive for me with the 992 is the tire noise, which is pretty damn loud. I don't mind it at all, but as others have stated the noise reducing glass won't do anything to combat tire noise. I feel like outside of this the rest of the "noise" is fairly light. Wouldn't mind a louder engine and exhaust, while we're on the topic of sound.
#55
Not sure if you have a caliper to measure the thickness of your door glass so we can have a comparison on here vs someone with the normal glass. It may or may not help in comparison because the edge thickness could be different. Just some ideas.
#56
#57
Does your door glass seem like it's dual layered like how others describe the thermal and noise glass on panamera, cayenne, etc? Not sure if you have a caliper to measure the thickness of your door glass so we can have a comparison on here vs someone with the normal glass. .
#58
Really with those wide low profile tires right under your backside that’s to be expected. Every generation Porsche say its better, but as far as I can tell its not.
#59
what sort of road surfaces do you have in Switzerland? Here in SoCal we have a mixture, from concrete to smooth bitumen. The concrete is very loud, the smooth bitumen very quiet. Down in Australia we have coarse chip seal, that’s very loud too.
#60
THIS. Most SoCal roads are concrete, which is super loud. Every now and then there will be a stretch of highway that's black asphalt (or bitumen, as you said) and I'll feel like I'm in a Rolls Royce with how quiet and smooth the ride becomes. I, too, am used to some louder cars and would rank the tire noise itself as being up there in the 992. Again, not a complaint at all...just pointing it out.
I don't know how those poorly endowed folks with the jacked-up trucks and the big mudders can handle the noise their tires make!
aggie57 (10-06-2020)
