992 Sound Symposer
992 Sound Symposer
I searched but couldn't find much in the way of an answer.
Do we have any clear details on the 992 Sound Symposer and what it entails? Is it a similar system to the 991? Does it involve any electronically generated sound like the 718 models?
Thanks.
Thanks.
Popular Reply
02-25-2020, 08:57 AM
The noise generator in my 992 is this big heavy metal thing in the back of my car. The volume control is located under my right foot. For some reason, it needs to be serviced every 10k miles. The faster I go, the louder it gets. Anyone else experience this? Between this and the nubbin, how does anyone live with this car? 🤪
The 718 involves "electronically generated sound"? This is the first I am hearing of this.
Edit: Wow, I didn't know they used the "sounaktor" like in the Audi and VW cars... That is no bueno.
You can pull a fuse - or actually disconnect the box for it - to disable it without any adverse effect.
The following 4 users liked this post by iliveoncaffiene:
It's a pipe percolating sound generated by a diaphragm, which vibrates in tandem with the exhaust. It's a way to pipe the sound and not gases in the cabin.
Nothing electronic. It's louder on 992 than 991.2. Once I change header and/or cats, it's coming out or will be blocked.
The following 4 users liked this post by John Mclane:
How does sport exhaust differ from standard exhaust?
Electronically generated sound was not the case in the 991 and .2 generations. The symposer was just an open tube from the engine compartment to the cabin.
Are you all sure there is a speaker with "fake" sound in the 992?
The 718 is a different story; it definitely has an electronic soundaktor device.
So I'm curious. That's why I'm asking for an actual system diagram / drawing like we had for the 991's.
Thanks all.
I just found this info about the 992:
Even so, the sound symposer first installed on the 991 series has added a second, switchable channel behind the rear trim panel to pipe more aural sensation into the cabin.
So it appears the 992 DOES have the SS ....FYI....
The 992 has a sounds symposer setup that channels sound. It's not fake engine noise.
russbert (02-24-2020)
Has anyone dug around in their 992 to find the sound Symposer? I ask because I have the soundaktor in my 718, which sounded terrible, so I pulled the fuse to much relief.The funny thing is, once I did that, there was almost no perceptible difference in engine note with PSE on or off, other than the burbles / farts, take it or leave it. Before pulling the fuse, the noise would leave my ears ringing after a long drive.
I hope the 992 is purely mechanical?
Porsche info on the 992 sound symposers: 992 has two sound symposers. Engine load varying pressure differences upstream of the throttle valve vibrate a diaphragm in each symposer, which causes engine sound to be piped into the cabin. The left symposer is always active. The right symposer can be activated when required via an electropneumatic converter, in Sport and Sport+ modes, and overridable by the Sport exhaust button.
Next to the oil filter cap you can see one of the pipes. The connector to the intercooler box is right in the middle. From there you can follow towards the cabin. The top of the picture is towards the rear.
