Turbos and Tune: Is that the only difference between a Base 992 Engine and S Engine?
#31
por356 (10-28-2022)
#32
992 S has bigger turbo than Base. 992 GTS has same turbos as 992 S, basically just a tune difference for the GTS in this generation. Buy the one you won't, don't plan on buying the lower model and tuning up to the higher, that is a fools game. Despite what people on the internet and some tune vendors claim, Porsche can determine that the car was tuned if they want to.
The following 2 users liked this post by colnagoG60:
AsherDad (02-05-2023),
tourenwagen (10-28-2022)
#33
I think Matt Farah tried to take a deep dive into finding this info out, by checking technical documentation, and checking with Porsche insiders. If I remember correctly, the turbo "housings" are the same size, but "inlet wheels" are slightly larger (1-3mm) for one trim lever over the other. He mentions it in one of the Smoking Tire 911GTS vids.
I am looking for some confirmation on the head swap. That’s a pretty big potential change in terms of air flow, etc.
#34
Flat-6 Motorsports should be able to confirm/deny...they offer turbo upgrade packages with OEM turbos. I was looking into getting a "Carrera T" to get the diff/PTV/manual/sound deadening removal over the base, but add GTS+ turbo kit to make a budget Sport Classic, at half the price.
BrianD185 (10-28-2022),
#35
I am getting the Turbo S. Patiently waiting my turn to order which shouldn’t be much longer. But I’d point out - the jump from base carera to carrera S isn’t life changing money. The gap from carrera to Turbo S might be for some. But I agree and reiterate what I said first - they are all excellent cars and I’ll add here - you won’t be sorry you bought any of them.
#36
I'm pretty sure the brake calipers are 6 piston on the S vs 4 piston the regular as well (or at least that is how the 991 generation was).
I went from a base 991 to S in 992 , but only because of the manual transmission is only on the S. Comparing the two cars I prefer the base just slightly in terms of fun factor. The S is really fast and I can't rev it like I pushed the non S because with the S would just end up at too high speeds .
#37
Sarcasm intended, to show the futility of the whole get an S over the base argument. There's always something with more power. pick the model that fits your need. There is no slow 992.
#39
Great question!
I've been looking for an answer myself.
Here is what I've found.
Point 1.
There was the obvious differences between the internals of a base 991.2 engine and that in an S confirmed by Porsche.
Look closely to spot all the differences.
Point 2.
There are still two part numbers for a 992 3.0 engine pistons - just like there is for a 991.2 3.0 engine.
Only one number for a piston rod remains for a 992 instead of 991.2's two though.
Two part numbers for an auxiliary belt for Base and S/GTS.
Point 1.
Point 2.
