Turbos and Tune: Is that the only difference between a Base 992 Engine and S Engine?
This denial of warranty for tuning modifications/exhaust system:
Do you have facts regarding P denying warranty work for items other than those modified?
I have been hearing this fear mongering for some time and want facts, not anecdotal evidence....
Now I seriously doubt a tune would blow an engine. And I seriously doubt an engine will suffer a catastrophic failure on its own. But if you are in that tiny fraction of people that suffer a catastrophic failure, it's PCNA or maybe just Germany that ultimately decide on major warranty claims and they will do forensics. If they discover a major modification relevant to a failure, then you need to be prepared to eat it.
Case in point - I'm considering lowering my car. I know that if the struts fail prematurely, I need to be prepared to pay for the fix myself.
Most times, that's never an issue. I've modified almost every car I've owned and haven't had a problem. My issue is with a dealer flatly telling people that the warranty is completely secure. That's BS. Anyone who modifies their car in a real way knows they are playing with fire and they accept that risk, no matter how small that risk may be.
As far as ECU tunes - most tuners operate well within a safety envelope to avoid problems and these engines are tough. It's more a question of being prepared if you are just plain unlucky.
The following 3 users liked this post by rk-d:
It’s been a few months since I posed this question. Wondering if there is more information available now?
specifically, I am most-interested in knowing if the only difference between the base and S engine is the turbos and the tune, or are there additional, supporting differences (fuel system, internals, forged vs cast, etc)?
I’m not trying to turn this into a “should I mod my car” or “will my warranty be void if....”. Plenty of threads on here about that.
My question (now): How are the two engines specifically different besides output?
Nine months later...still curious. There are fifty videos on youtube explaining the difference between the 2021 Toyota Supra and 2022 Supra engine, but nobody seems to know or talk about what are the differences in the engine in a 992 Carrera base and S. I have read elsewhere that the turbos are different (the S models are larger in diameter). We know the power output is different. What makes up that difference besides the turbos and the tune? Anyone have a good resource? Thanks!
An interesting note is that the 992 GTS is the engine that Porsche developed and the 992 S is the GTS detuned by Porsche, which is just kind of funny since it came out first. However, the base engine does have smaller turbos, as well as other chassis, suspension, and brakes differences. I'm not sure other than the turbos in what way the 992 base engine differs from the S.
I am also curious about the internals on the base and S, in the past they have had differences in terms of piston type, connecting rods ect. Basically the 992 block is designed to be built up to GTS levels with stock base internals? is there additional cooling or oil delivery changes?
The following 8 users liked this post by M Engineering:
3RsInCarrera (11-10-2021),
balucipher (10-28-2022),
Master Deep (11-10-2021),
por356 (10-28-2022),
rmb1973 (06-23-2024),
and 3 others liked this post.
Thanks Charles! I was hoping you would reply! I was reading your thread and looking at your website today and thought you might have some first-hand knowledge to share!
So a base and an S with your Pure 800 upgrade and your ECU tune produce near-identical power and torque output? No fuel system upgrade or anything else required? That's pretty much what I would have guessed because it's likely less expensive from a supply chain, economy of scale and assembly line simplification perspective to make the engines identically, with only minor differences for the specific application.
Platinum Sponsor
That would be a really fun test to do. If all conditions are the same, in theory they should be essentially identical based on what we currently have found and know. You'd need to run identical fuel, on the same day, same dyno, same settings, same temps and same calibration changes to the tables.
-Charles@M
The following 2 users liked this post by M Engineering:
3RsInCarrera (11-11-2021),
tourenwagen (10-28-2022)
On the 991.2, the engine was identical between base, S , and GTS. Zero difference. Porsche’s part number system proved this. It is all the turbo’s and the tune,
I would imagine the 992 followed a similar model.
S engine
That's precisely my question. Specifically, what are the engine differences between the two? There is alot more data available about other manufacturers' engines and the differences between versions and variants than there seems to be concerning Porsche engines it seems. Maybe I just don't know where to look. There was a great article on here about the differences between the 991 motor and the 992 motor. Just curious about the base and S is all.
Bigger turbos, more boost, bigger injectors and different cylinder heads and cam timing is what I was told. Plus some options - pasm, better brakes. I have the S. Lots of passion around this question - any 911 is an amazing car. Some argue the base is a perfect balance. It might be. But if you have 911 money and are buying a sports car, why not get the S?.
992 S has bigger turbo than Base. 992 GTS has same turbos as 992 S, basically just a tune difference for the GTS in this generation. Buy the one you won't, don't plan on buying the lower model and tuning up to the higher, that is a fools game. Despite what people on the internet and some tune vendors claim, Porsche can determine that the car was tuned if they want to.
Everyone has their own individual sweet spot in terms of performance vs dollar value proposition. There are no bad choices.
por356 (10-28-2022)
