Unstable at speed
Old 04-06-2020, 10:50 AM
  #46
rk-d
rk-d's Avatar
Received 6,478 Likes on 2,816 Posts
Guys -- this is not a characteristic of 911s -- old or new. They do not feel squirrely at speed. If your car feels unstable > 90 MPH, either there is something wrong with your car or with your perception.
The following 8 users liked this post by rk-d:
AlexCeres (04-07-2020), Crester (04-07-2020), dhirm5 (04-06-2020), mathus7 (04-08-2020), Noah Fect (04-06-2020), SamD (04-06-2020), smiles11 (04-06-2020), TennisGuy (04-07-2020) and 3 others liked this post. (Show less...)
Old 04-06-2020, 10:55 AM
  #47
2020
2020's Avatar
I don't think its anyone's perception. I have gone much faster in other cars and did not get the same "perception"
Old 04-06-2020, 11:45 AM
  #48
rk-d
rk-d's Avatar
Then their cars are screwed up - likely alignment. But it's not an inherent characteristic of 911s to be unstable at such low speeds.
The following 2 users liked this post by rk-d:
dhirm5 (04-06-2020), TurboS_GG (04-06-2020)
Old 04-07-2020, 12:40 AM
  #49
AlexCeres
AlexCeres's Avatar
Received 1,685 Likes on 1,033 Posts
My 911 is significantly more stable than my M3. At 100 it feels about as stable as the BMW at 80. I don’t know what speed it takes to feel unstable, because driver fails before car.
Old 04-07-2020, 01:42 AM
  #50
BSO
BSO's Avatar
I feel for you guys, my 991.2 C4S with RAS is rock solid at speeds up to 100mph and cruises on the interstate like on a string. I've taken two long road trips with it and no issues.
Your 992s should do the same. Mine came with Michelins and they are great. I saw at the dealer that some of 992s are now coming with Goodyears, have had issues with the brand and wouldn't have them on any of my cars.
Those of you that do have the instability should see if tires are a common denominator. As to alignment, no issues as well, car steers straight, no pull and even wear at nearly 10k miles.
I've also varied my tire pressure, but the only effect has been that at pressures over the comfort setting, the ride is rougher, currently running 30/35 and will lower those cold pressures once summer gets boiling.
Good luck in finding the solution.
The following 3 users liked this post by BSO:
AlexCeres (04-07-2020), SamD (04-07-2020), TennisGuy (04-07-2020)
Old 04-07-2020, 01:54 AM
  #51
crimewave
crimewave's Avatar
Good to know, my M4 comp came with Michelin PS4S as standard and I loved those tires a lot. A bit bummed about the Goodyear's, especially if that's the cause for the issues I'm having.
Old 04-07-2020, 02:28 AM
  #52
HouTexCarreraS
HouTexCarreraS's Avatar
I have Pirelli P Zeros and have the issues. I don't think it's the tires--possibly an alignment problem.
Old 04-07-2020, 03:55 AM
  #53
sbutty45
sbutty45's Avatar
And so I have Goodyears.... so if HouTexCarrera has Pirellis then we have same issue but different tyres..
Old 04-07-2020, 10:30 AM
  #54
Golfster
Golfster's Avatar
Goodyears, RAS/PDCC here and haven’t experienced this.
Old 04-07-2020, 11:18 AM
  #55
russbert
russbert's Avatar
This (quote above) because I have owned multiple Porsche's now (still waiting on 992 to be made) and ALL of them were extremely planted at triple digits. The red 996 turbo in my signature I took over 150+ mph multiple times with absolutely NO issues.
The ONLY times I had issues were either with alignment, a bad tire (it rarely happens, but it does happen), or when I had my front chin on the aerokit removed due to damage and wanted to see how much of a difference it made (the answer was a LOT).
Old 04-07-2020, 03:16 PM
  #56
Penn4S
Penn4S's Avatar
Received 1,337 Likes on 753 Posts
I agree with this. I have had over a dozen 911's and in all honesty have never felt any instability other than when tires were over inflated or past the worn stage for driving.
911's do drive differently than a lot of other sports cars as the rear engine bias does create some different feelings when driving but having the confidence to trust the car and experience the different dynamics.
If you guys are having real issues as described get the dealer to address immediately as it is not normal.
Old 04-08-2020, 01:55 AM
  #57
RacyTracy
RacyTracy's Avatar
And I was hoping that it was because I'm on 4 winter tires.
Old 04-08-2020, 08:01 AM
  #58
PBM
PBM's Avatar
Goodyears, RAS, non SPASM , door sticker Comfort pressures , C4S 5.5K miles in , mainly in dry, sometimes in wet........sometimes( ) pushing it .......PLANTED
Old 04-08-2020, 12:05 PM
  #59
2020
2020's Avatar
Just had an alignment performed- maybe a 30-40% improvement.
Old 04-08-2020, 12:18 PM
  #60
mathus7
mathus7's Avatar
Same combo - no problem. C2S
Quick Reply: Unstable at speed
