Winter - Non staggered setup?
I purchased a winter wheel/tire set for my 991.2 C4S cab. I have a 992 C4S cab on order and I'm wondering if I can use the same wheels/tires. I know the 992 has staggered 20"/21" inch wheels but for winter wheels you can use 19"/20" or 20"/21".
My question is can I use non staggered 20" (20" for all 4)? Bonus question...are the TPMS sensors the same for 991.2 and 992? I have 433MHz sensors for the 991.2 set.
Here's what I have:
FRONT
20X8.5 5-130 ET47 wheel
245/35R20 tire
REAR
20X11.5 5-130 ET59 wheel
295/30R20 tire
Thanks!
Here's what I have:
FRONT
245/35R20 tire
REAR
295/30R20 tire
Thanks!
See this thread... https://rennlist.com/forums/992/1181...l#post16424244
Aventurine 992 is running 20s at all four corners.
Here's what I have:
FRONT
245/35R20 tire
REAR
295/30R20 tire
Thanks!
Here's what I have:
FRONT
245/35R20 tire
REAR
295/30R20 tire
Thanks!
If you keep the 20” wheels on the 992, you may want to use rear tires with a higher sidewall to preserve the overall diameters. This also has the side benefit of improving snow performance.
you Can do this, but need to get new rear tires. Have to go with 35 sidewalls instead of the 30’s on the 991. The tpms is different too. I tried this for my car, but gave up and negotiated a reduced price on the factory 19/20 setup
Here's what I have:
FRONT
245/35R20 tire
REAR
295/30R20 tire
Thanks!
Here's what I have:
FRONT
245/35R20 tire
REAR
295/30R20 tire
Thanks!
Hopefully TireRack will starting getting more wheels for the 992. They currently only have O.Z. Leggera HLT wheels in either gray or black in the 20"/21" staggered set-up and the black wheels are out of stock at the moment. My preference for all of my cars is to have a set of nice but cheap winter wheels/tires and change them over myself when winter comes around.
