Does the C2 have a LSD?
Is this something I should be concerned about? There are no C2s anywhere near me yet, nor any 911.2 C2s, so I'm just going on what I've read regarding the differences between the base car and the S trims that I've driven.
PTV+ is available as a $1500 option on the C4, but it is not currently available for the C2. It's standard on the both the C2S and C4S models.
I suppose I'm unclear how much of a difference a LSD would make with the 911. Also confused why it's on everything except the C2.
Since the new cars have a pretty sophisticated Traction Control setup (electronically mimics LSD), the missing LSD may not be tragic. But, any serious sports car should have a real LSD in my opinion (particularly if driven on track). Note: some pretty serious cars don't have one though (like McLaren).
I wonder if the aftermarket will come to the rescue? You can usually pickup high quality differentials for other makes between $800-$2000
Some good videos of how they work, advantages etc
https://www.youtube.com/results?sear...p+differential
EDIT
Looks like OS Giken (Japanese racing company) makes one to convert 991 open diff to LSD so it might be possible. I would want one from Quaife in the UK. They can probably make something really nice and streetable.
https://flat6motorsports.com/product...dk-991-997-987
With PSM on the car still effevtively has an eDiff, no?
I drive it like a Porsche, but no track use. So probably maxing at 7 or 8 out of 10.
Also, Porsche uses a Clutch-type LSD on all its 911's (for over 50 years) and this type of LSD (as specified by Porsche) actually has more locking under braking than on acceleration, so there is a big improvement to stability under braking (doesn't wag its tail). Other types of LSD's (like Torque Biasing Diff) do not provide this important benefit.
Frankly, this is a deal-breaker for me re: base C2. I had no idea a $100K-plus RWD sports car would be equipped with an open diff, WITHOUT the ability to option LSD. (Brake-based torque vectoring doesn't count in my book. It's a poor substitute, at best.)
I've owned several high-horsepower RWD cars. All had limited-slip differentials as standard, or optional. (If it was the latter, I optioned it. I would not consider buying otherwise. I've driven a few open-diff RWD cars in various iterations, and was uniformly disappointed in traction dynamics. Every. Single. Time.) Even had two FWD performance cars with limited slip diffs -- one was a viscous type, the other Quaife.
I digress. The point is, fellas, THANK YOU for pointing this out regarding the C2. You cost me at least $7K to run up the chain to a C4, or $16K / $23K more for a C2S / C4S. I despise Porsche's marketing / sales / option practices. But I love their cars, and need another one. They just slid another chunk of cash out of my pocket with this revelation. Effers.
