Sport Auto says skip the RAS and PDCC
Please provide some documentation (preferably illustration) to support your claim. The change to the engine and gearbox mounts do not mean the drivetrain itself has moved forward. It's my understand that the 992 is still very much a rear-engine car. My 991 does not feel at all like a mid-engine car to me. But even that is irrelevant - it either is or it is not rear-engined. Very easily proven one way or another with a proper illustration.
Found this cutaway, but it is not the best view (though doesn't convince me at all that the engine is "over the rear axle"):
https://www.total911.com/what-weve-l...e-991-chassis/
"The big issue lies in engine placement. For the 991, its flat six engine is placed more on top of the rear axle, rather than past it. This calls into question just how ‘rear engined’ the 991 actually is, especially when compared to the full-bodied rear-engined nature of every single Porsche 911 that preceded it. As well as the engine’s incremental shift forwards, the ‘mid-engine’ feel is supposedly exacerbated by the 991’s extended wheelbase, which is 100mm longer than that of the previous generation 997."
GVIFlyer (10-11-2022)
See my second illustration above - more clearly shows the engine is behind the rear axle line...
how much do the dynamic engine mounts being added have to do with this relocation of the engine? or are they two mutually exclusive design improvements?
If you think about how things would look if the engine were truly mid-mounted at the rear axle line, the transaxle gearbox would be way in front of the rear axle line). So the exit from the transaxle of the drive shafts (half-shafts) would have to be mounted at a severe rearward angle to reach the wheel hubs. This would not be good (and this is not how it's done).
992Sam (01-21-2020)
Received 2,842 Likes
If you want a mid-engined Porsche, they have the Cayman/Boxster. Just sayin'.
992Sam (01-21-2020)
How did this become an engine thread?
I tried cars with RAS and without. You can definitely feel the RAS, but that's a pro and a con. Yes, it helps turn in.. but you can feel it helping turn in.
Also I'm sorry but I laugh whenever someone suggests RAS helps "highway stability" and parallel parking. Really? The 911 is lacking "highway stability" and is hard to parallel park without RAS? Come on.
Driving a 992 w/out RAS I didn't notice anything particularly difficult about parking or stability. Hyperbole is hard to tease out in some of the reviews.
dchang81 (01-25-2020)
clearly the people on here know something the Porsche engineers don’t .. I mean standard equipment on the GT cars .. I’m sure it was just for the added weight, right?
I would just as soon answer the question myself, but I don't have access to a RAS equipped car to test.
No issues with parking at all (Steering Plus, but no RAS), easier as with my Prius.
Did 150mph max so far (winter tires), no stability issues at all.
That it helps with parking and u-turns is a positive side-effect.
While modern 911s are very stable at speed, having all four wheels turning in phase during high-speed lane changes does increase stability...for a GT car, especially in inclement weather on Cup tires.
It's a definite yes for a regularly tracked car, no question. Hence why it's on GT cars, which are incredibly complex examples of the 911. The GT cars also integrate the RAS better, which was a complaint on 991.2 S/4S cars and supposedly improved to some extent on the 992, although I can still feel the RAS working. The point is you might get a better feeling car in real world use without it.
Personally I've yet to find a car/suv/truck I can't U-Turn or parallel park in a busy city (Seattle) and I would argue there's a certain gravitas (and humor) in doing so in a 911 without the assistance options (PS+ and RAS).
yooj (01-21-2020)
