WIRING Instructions for Led Illuminated Door Sills
It is quite simple with the factory instruction. Plug and play. So just go ahead.
1. You have to remove the door sills by pulling upward about 1,5cm then slide backwards.
2. Remove the old one (take years to clean 3M adhesive...LOL)
3. Put the new ones on the same position (take care the slim led wires (don’t pull or twist)
4. Run the led wire along the gap between carpet and door sills.
5. You will find the harness as instruction. Put the pin in the vacant position (don’t worry you won’t make mistakes, there’s only 1 empty slot for the pin).
Enjoy your work!
Enjoy your work!
If it's easy as you seem to indicate, this appears to be the one OEM mod that is CHEAPER from a vendor than buying pre-installed from the factory.
I would like the instructions please. This is something I didn’t order from the factory and wished I had. My email is leem8084@gmail.com
@alexcalderon91 and @kpblade I have sent these to you via email as I received these from the original poster.
Just out of interest why don't you just post the instructions?
siberian
siberian
The following 2 users liked this post by siberian:
mikey94025 (02-28-2021),
Styrofoamboots (02-28-2021)
The following 3 users liked this post by Lee8084:
Great, thanx
siberian
siberian
Just curious if anyone else did this mod? I'm about to buy the set from Suncoast. Is it about as difficult as this guy, except for these you run a wire between the carpet and the door seal to the fuse box?
I installed my own dashcam. Is this about the same level of difficulty?
Here's the diagram I have for interior lighting . .
