Passenger side mirror tilts up when in reverse
My passenger door mirror annoyingly tilts up (instead of down) when reverse is engaged...which is a pain when parallel parking...something I do regularly. Took it back to the dealer the day after delvery and they somehow fixed it quickly. Now, 4 weeks later, it's back.
Anyone know what the secret fix is?
This is an overly simplified response, (apologies in advance), but when in R, adjust the passenger mirror to your preference and make it part of your memory settings (settings on the door). My car is away getting the SPA treatment currently otherwise I'd be happy to give better step-by-steps.
The following 2 users liked this post by Golfster:
NigelPlays (10-30-2019),
PBM (10-30-2019)
iF you grab a different key on any day the memories of that key may not reflect the proper settings unless you set them. Get used to any adjustments you make while in the car hitting the mem and key button to saver them.
Correct, when moving to D, the mirror will return to your saved setting in D. Note that it takes a few seconds before the mirror returns to the D position (slight delay).
