XPel on headlights
Porsche has advised against PPF on the headlights. Your installer is not steering you wrong.
IDK but 992, but previous models the owner's manual said don't film headlights. Check the owner's manual as it might have changed.
The reasoning is the headlights have coating to prevent yellowing from UV. My last car needed the headlights replaced because they started 'spider cracking' even though I never used film. I think some chemicals can trigger it to do that. What's weird is it looked like the whole plastic completely deteriorates... its not just a top layer.
I just had Expel Ultimate Plus put on whole car and installer would not put on headlights.
I put it on the car. As I understand it the problem could occur when you pull it off. To me it was worth it over pitting.
Received 3,366 Likes
Check out several threads in the 991 Forum. The general consensus is that if it is done properly there will not be any problems, and the better installers should agree.
This. They could delaminate without film. If you film and they do, a body shop can fix this. Replacing due to pits and chips costs far more.
Basic Sponsor
Location: 21620 Ridgetop Circle, Suite 190, Sterling VA 20166
We apply film to all Porsche headlights without any issue, We don't use Xpel as it has the most aggressive adhesives and most predominant orange peel effect. At the end of the day an 8mm thick film will protect exactly the same as another 8mil film no matter who's name is on it. anyone who tells you different is just playing into marketing hype. All the Urethane (the protective thickest layer) in PPF comes from only a few key suppliers globally. The adhesives and top coats make them different. We use STEK DynoShield as it is the most optically clear film on the market, has a self healing and permanent hydrophobic top coat and also the weakest adhesives. Many installers won't use it as it requires more skill to install as it's not as sticky as others. I agree with the above statements though. Properly installed (no adhesive promoter ever and not using Alcohol as a tack solution) you shouldn't not have any issues with any film on the lights. That being said I would just stay away from Xpel as the risk to delaminate the oleophobic top coating of the headlight increases.
~ Automotive Restyling & Protective Solutions ~
~Perfection & Nothing Else ~
GlasWerks DMV Online
GlasWerksDMV on Instagram
21620 Ridgetop circle, suite 190, Sterling VA 20166
001-571-370-8500
001-571-370-8500
Monday-Friday 8am-8pm EST
Premium Sponsor
We've been installing ppf on headlights for years. in the right hands, it's not an issue. We highly recommend and do it on every car
https://rennlist.com/forums/991/1030...-to-avoid.html
Specializing in Porsche/Ferrari since 1995
Why choose GP...WATCH OUR DOCUMENTARY
Follow Moe HERE
GP Fastrak - Ceramic/PPF/Tint in one simple bundle - Click Here for more info
Follow Moe HERE
Here's another way of looking at it:
1. Don't apply PPF to headlights. Headlights eventually get pitted or take a rock hit = must refinish or replace headlight.
2. Apply PPF to headlights. Film eventually gets pitted or takes a a rock hit = must replace film. If film comes off, great. If headlight gets delaminated = must refinish or replaces headlight.
Either way, you're replacing a headlight in worst-case scenario.
google “Porsche headlamp delamination from PPF”. It’s an issue IF the installer removing the PPF is not experienced. Must be done slowly with lots of heat. Otherwise the UV clearcoat will be damaged. Tons of folks have added PPF with no problem. The other thing to think about is that, without PPF, you will either be refinishing or replacing the headlamps after so many years. With PPF, they will be like brand new, but you run the slight risk of delamination. So which is it: certain damage or a slight risk of damage. The delamination can be fixed by polishing/refinishing the headlamp; the same procedure you would use to fix UV and road debris damage. We did the headlamps on our 992. Actually, we did the whole car.
Premium Sponsor
Basic Sponsor
XPEL
Our official answer is that XPEL and Porsche do not recommend applying PPF to Porsche headlights.
As others have said though, install at your own risk if the benefit of protection outweighs the possibility of delamination.
To clear up another item on this thread, not all PPF's are created equal and most films are 8mil thick not mm as mil and millimeter are completely different units of measurement.
XPEL Inc.
Support@XPEL.com Phone: (210) 678-3700
XPEL.com "Like" us on Facebook Follow us on Instagram
XPEL Inc.
GlasWerksDMV (10-23-2019)
I have seen an improper ppf install on my client's 991 headlight. It looks bad and the installer did not take a hit for it. Bad business.
Anyway, I would rather take the delamination instead of replacing $2500/ headlight. Refinish them and recoat or refilm them.
I know that every ppf installer has different skills, so it really depends on them and not the headlights. It may or may not delaminate with install or removal.
