Why 20" front and 21" rear?
Old 07-31-2019, 12:15 AM
titleistaddict87
titleistaddict87's Avatar
Default Why 20" front and 21" rear?
Wondering why they did this?
Old 07-31-2019, 12:40 AM
Psorcery
Psorcery's Avatar
Traction and stability.
Old 07-31-2019, 12:45 AM
ipse dixit
ipse dixit's Avatar
Received 11,537 Likes on 5,061 Posts
Increase rear end traction (esp. important since the 911 has a rear weight bias)
Increases the rake, which allows for greater downforce and better front-end grip
Old 07-31-2019, 09:19 AM
gatorfast
gatorfast's Avatar
How does having this stagger create better traction?
Old 07-31-2019, 09:41 AM
iliveoncaffiene
iliveoncaffiene's Avatar
I think most try to argue you have to have bigger wheels to have wider tires.... well no that's just not completely true.
I think the "rake" answer is more true for traction - and the other side of it is simply aesthetics.
Combination of filling out the wheel wells to fit the desired aesthetic + wanting a certain sidewall height (for road feel: shorter sidewalls = less squirm).
Then there's how easy it is to get a certain tire aspect ratio, what that might cost from manufacturers, etc....
It's definitely not simply "more traction"
Old 07-31-2019, 10:09 AM
911boy
911boy's Avatar
Traction. Contact patch on 21 is bigger than 20.
Old 07-31-2019, 11:33 AM
STG
STG's Avatar
Wider and heavier 992 needs it to hit performance targets. Still find it bizarre. The GT3 doesn't even need a 21", but the RS does have it.
Looks odd on the Carrera line of models in my opinion.
Old 07-31-2019, 01:09 PM
titleistaddict87
The staggered setup just seems like a hassle to me, especially on non-GT models but there must clearly be an engineering reason for doing it. It does increase rake slightly while preserving wheel / fender gap for aesthetics. The increased rake would put incrementally more weight over the rear for traction.
i also can’t help but think it’s also in preparation for electrification / hybrid tech in the 992.2, perhaps because the electric motor is going to be in front.
Old 07-31-2019, 03:27 PM
gatorfast
gatorfast's Avatar
Right I agree. Diameter is different than width and an 11" wide wheel for example, whether 20" or 21" in diameter, should have a tire with approx the same contact patch. Its only the aspect ratio which changes and generally a "thinner" tire with a lower aspect ratio can actually have worse grip as there is less flex in the sidewall under hard acceleration and cornering.
I am thinking the stagger is mainly geared towards aesthetics rather than performance.
Old 07-31-2019, 03:34 PM
gatorfast
gatorfast's Avatar
That is not true. 21 and 20 are referring to the diameter of the wheel and not the width, which is what influences tire contact patch and traction. For example using a Michelin ps4s tire, a 295/30/20 tire has the same width/contact patch as a 295/25/21 tire. So moving up from 20" to 21" produces no difference in how much rubber is on the road.
Old 07-31-2019, 03:50 PM
911boy
911boy's Avatar
I realize that we are talking diameter. According to August Achleitner, VP of sports cars for Porsche, they went to 305/30/21 for slightly increased contact patch.
Old 07-31-2019, 04:27 PM
Freddie Two Bs
Freddie Two Bs's Avatar
Yes, bad aesthetics is surely a factor. The wheels on the turbo look even bigger, maybe 22" rear? Because 21 wasn't enough of a monster truck look.
Old 07-31-2019, 05:12 PM
dkmesa
dkmesa's Avatar
But it will have 305/30r21 compared to 991 305/30r20, so while the width that meets the road may not be notably different, the contact patch in theory will be slightly larger due to taller diameter/ larger circumference and more rubber meeting the road front to rear of the tire's surface.
Old 07-31-2019, 06:20 PM
gatorfast
gatorfast's Avatar
Yea I just remember the days not too long ago where 20"+ wheels were reserved for Escalades driven by rappers. How the times have changed lol
Old 07-31-2019, 07:12 PM
STG
STG's Avatar
26" wheels are the new 20"
